Old 06-19-2021, 11:35 AM   #1
Tadshy
Tadshy's Avatar
Default 3rd Gen Camaro wheelie bars
Does anyone have a suggestion on wheelie bars. I Have an 83 Camaro Super Stocker that I run in GT/MA. The right side wheelie bar recently got bent and I need to replace them. Not sure if I should just get another set like I have which are the older style with the flat bottom bar and the spring loaded upper bar. Just wondering if someone is using a different style that would work better.
Thanks.
Tadshy is offline   Reply With Quote
Old 06-19-2021, 06:13 PM   #2
jimmyparker
Liked 309 Times in 88 Posts
Default Re: 3rd Gen Camaro wheelie bars
Search S&W Race Cars for F-body wheelie bars.
jimmyparker is offline   Reply With Quote
Old 06-19-2021, 07:49 PM   #3
SSDiv6
Thanks.
Get away from the flat leaf style wheelie bar and like Jimmy Parker stated, look at the bards sold by S&W with the NHRA Stock Eliminator legal length and attachment points.
Old 06-20-2021, 12:29 PM   #4
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
My 91 Formula has wheelie bars from PK Race Cars . They work well , all round tube , top bar sprung , and are built to easily use a floor jack under the rearend . I recommend them .
ss3011 is online now   Reply With Quote
Old 06-20-2021, 03:54 PM   #5
Tadshy
Tadshy's Avatar
Thanks, Do you have a website or phone number for them? I looked but couldn't find anything.
Old 06-20-2021, 07:00 PM   #6
ss3011
ss3011's Avatar
I guess the real name of the business is PK Race N Rods , they are in Millersport , OH the phone number off the web is 740-407-6848 . Hope that helps , they are well know and race Super Stock in Div 3 .
Old 06-21-2021, 04:17 PM   #7
Tom Goldman
Tom Goldman's Avatar
Liked 885 Times in 238 Posts
The S&W bars are a good choice , they fit with no issues.
Ken Keir's mono bar is also good if you have a larger budget .
Tom Goldman is online now   Reply With Quote
Old 06-23-2021, 10:10 AM   #8
Adger Smith
Liked 880 Times in 311 Posts
If you can balance your car it might run quicker without them.
My gen 3 is about a nickel quicker without them.
It is the unsprung weight that my set up doesn't like.
I found it when I put my spare 6.50 third member in..
I took out an aluminum and installed an iron (same spool and gear ratio) Strange third member. Found that same nickel that shows up when I just mount the wheelie bars.. Ride along, no use...but if you need them there are a lot of ways to use them.
Adger Smith (Former SS)
Old 06-26-2021, 02:32 AM   #9
Tadshy
Tadshy's Avatar
Thanks for the info.
