Old 06-22-2021, 09:32 AM   #1
SDT1DYI
Liked 456 Times in 148 Posts
Default Re: Data Logger Worth it or Not?
If your trying to go fast, yes they are a must have. If one is not, then the 2 K plus cost, by the time you get O2s, lap top etc, could be put to better use with a limited budget..
Steve Teeter Stk/SS 620
SDT1DYI is offline   Reply With Quote
Old 06-22-2021, 12:59 PM   #2
Dean Feiock
Dean Feiock's Avatar
Liked 49 Times in 15 Posts
True cost against the value added was the original thought with my previous post.
So use my combo as an example. I've had this car for over 20 years. Let's say I can run 1.00 under without to much effort. Lets say the new engine makes 20 HP more than the old one. Let's say the new transmission is worth a little more as well. So let's say that I believe I can go faster in the near future.
Is a $1000 Sportsman system worth the money for the limited data gained?
Is $1500 for the Sportsman system with single channel add on O2 sensor worth the money?
Would a $1700 V300 system be a better choice? Or would I also need the add on single channel O2 sensor ( bringing that system to $2200)?
And I think these options would still be considered "entry level". I could see a full system hitting $3000 to $4000.
All opinions welcome...
Dean Feiock -- Stock 5002
Dean Feiock is offline   Reply With Quote
Old 06-22-2021, 01:39 PM   #3
SSGT Mustang
Liked 204 Times in 54 Posts
I never had one. Then I got one. Now I'll never not have one.
Not only does it help you understand where to pick up, it shows you when you're running into trouble. Oil temperature comes to mind. Same with oil, fuel and transmission pressure.
People will spend $1500 on a weather station and not even think to buy a basic racepak. It makes no sense. If I had to choose between one or the other, without a second thought I'd choose the racepak.
SSGT Mustang is offline   Reply With Quote
Old 06-22-2021, 01:53 PM   #4
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Dean,
When I built my car for Stock, I purchased a Computech DataMaxx, it is a built up system and still in the car. Originally it was engine and clutch monitoring. Oil press, water temp, O2 in both collectors, input shaft, driveshaft, accel. I mainly monitored what the clutch was doing, and that is all it does now since switching to SS and EFI. The EFI now logs the engine vitals. I will say this as someone else pointed out. I discovered why I was having oiling issues with the EFI combo by the data logs. Seeing oil press fluctuating as the engine accelerated and would recover. Adding an additional quart of oil and the problem went away.
Its an investment, and more info to validate what you think just happened on a pass, if everything is healthy, or setup as efficient as possible. If someone is not into looking at data it is not a worthwhile investment.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 06-22-2021, 04:00 PM   #5
SDT1DYI
Dean, I put a used Sportsman in. O2's in the collectors. Found a racer upgrading to V300. 600.00 (I have only 2 jets ). Auto 1-2 shift. Got a lot of information on shift points and learned, leaner was a little faster. All good data.
If there was a lot of fast cars in ones class, yes it then should be very helpfully.
I know guys that have 6-7K invested in the F, G and H stockers data systems. 25K in Comp cars!
Some of the " Dime Rocket" cars that can run 1.30-1.40 plus under, I would think investing in a Data recorder is unnecessary and not cost effective.
So I see it as fewer the cars in your class and slower the class, Data recorders become a fun tool but are not going to provide a return on your investment to win rounds.
Just my view.
Steve Teeter STK/SS 620
Old 06-22-2021, 05:43 PM   #6
AveryMcLawhorn
Liked 80 Times in 19 Posts
Very interesting point. Obviously I have a slower class car and trying to weigh were the money is best invested as I am on a budget. I know I will never have a 1.00 under car but I'm shooting for .4 - .5 under.
Just my view.
AveryMcLawhorn is offline   Reply With Quote
Old 08-16-2021, 08:50 PM   #7
dean ribeiro
Liked 241 Times in 80 Posts
I second the vote for Gregg Kelly @ Motorsports Innovations! He is extremely knowledgeable, helpful and, in my case, patient! His customer service nd responsiveness is 2nd to none!
dean ribeiro is online now   Reply With Quote
