Liked 734 Times in 385 Posts
How about we ask a different question. How many feel that the data supplied from runs and about changes saved you both a nice amount of both time and money?
Stan |
Liked 19 Times in 11 Posts
i have a racepak sportsman with a o2 you don"t know what your missing without one great tool wouldn't be without one
Liked 348 Times in 79 Posts
The rpm DL10 seems to be the most cost effective for those on a budget. Can the 2 o2 package be added to the DL10?
Liked 226 Times in 76 Posts
This is our 1st racing season with one. (Racepak Sportsman) Here are the ways it helped us, above better dial-ins. So far it has helped us to fine tune the A/F since we have the 02 sensors in the collectors. Shift points, launch rpm's and tire pressure based on driveshaft rpm vs engine rpm and the acceleration G's. It helped us diagnose a voltage drop on the run when we were .05 slow to our dial. Tracked it to a loose alternator plug. Then further dug in and found a voltage sucking on-off master switch. Yesterday we went out to do some bracket racing. Car was just as fast as it should be in the air on the 1st pass and we thought we had zero issues. On the run the data showed we dropped from ~45psi Oil pressure on our SBC to ~7psi. Packed up and headed home after watching our friend go a few rounds. Don't know the damage yet, but ZERO indications otherwise we had an issue. We are saving $$ and possible my hide with that data logger. If we made another time trial and the motor let go and shot oil everywhere who knows what happens. Never thought a data logger was a safety purchase too, but it could be. I wouldn't race without one. That is just me. I tent camp when I race multiple days and shower with a modified weed sprayer. I am not a baller. The $2500 we have in our data logger was NOT an insignificant purchase to us.
Andy Friar |
#5 | |
Liked 125 Times in 59 Posts
Happened to me last year. Saw really low oil pressure, put it in the box and went home. Pulled the engine apart and blackened the crank, had some not great looking bearings but saved the engine. New crank, oil pump and bearings and back to racing. Just a bracket engine but the only one I had at the moment. |
Liked 21 Times in 7 Posts
Avery - we picked up maybe .03-.04 so far with small tweaks in limited runs but the safety factor as others have mentioned is worth the investment X10. We've found lean spots in the tune-up that have slowly been ironed out so the engine is happier everywhere in the run (burnout to stripe). Our tune-up will never be perfect, but a data logger allows us to intentionally "chase hp" with far less guess work.
I think there's likely a benefit with consistency as well as you can slowly improve each aspect of the combo and get it all into a healthier spot. Having ample data really accelerates the development curve since you have empirical visibility to so many more things that are going on during the run.
Greg Viscome 193 GT/QA |
#7 | |
Liked 80 Times in 19 Posts
Based off everyone's information, what are the recommend bare basic sensors to start with? What was the most valuable sensors added to the car? Thanks, Avery |
#8 | |
It inputs just like any other sensor though the WegoIII board. Last edited by curtis reed; 08-16-2021 at 03:16 PM. Reason: changed box to board. |
