Old 04-02-2008, 08:03 PM   #1
Camaro Nut
Default Re: Lt 1 ???
What is the weak link on a stock short block? Is it the rod?
Camaro Nut is offline   Reply With Quote
Old 04-02-2008, 08:34 PM   #2
Liked 1,913 Times in 429 Posts
If it has powdered rods, yes, the rod is the weak link. That doesn't mean that's the first, or only thing that will fail. But I'd replace the rods if I was going to race it.
Old 04-03-2008, 08:06 PM   #3
Camaro Nut
Do you think if I was to take a stock short block and install a good set of rods in it I would be able to get away with running it like that for about 100 runs. I am just trying to get the car out and get some runs on it to see if the susspension works and then have a good bullet built.
Old 04-03-2008, 08:17 PM   #4
Woodro Josey
Liked 3 Times in 1 Post
Alan is correct about the rods, and while it is down, get someone to hone it with torque plates. Also, the Optispark is also a weak link, go ahead and purchase the MSD Rotor and Cap kit and this should take care of that problem!
Woodro Josey 2002 STK
Woodro Josey is offline   Reply With Quote
Old 04-03-2008, 08:33 PM   #5
That's a thought Woodro. If you take it apart, to replace the rods, you'll have to balance it as well. But if you'll hone it with torque plates (have this done by a shop capable of doing RACE work) and get a ring package (made for Stock Eliminator) from some one like Total Seal, Childs and Albert, or Ackerly and Childs, and set the deck height, you'll get a good return on your money. Woodro can probably steer you right on a ring pack. His little LT1 whips up on my 427!
Old 04-03-2008, 09:36 PM   #6
Originally Posted by 1664SSJA View Post
With all that being done his "stock bottom end" is only pistons away from a good piece.
Go the distance!
Not really. I'd want to pour it and bore it before I'd invest in new pistons, and it'd also get align honed. It'd need a fully prepped crank (blueprint stroked and indexed) as well. A lot more money and work.
