Old 08-04-2021, 09:00 AM   #11
6130
Liked 117 Times in 50 Posts
Default Re: off idle stumble
Originally Posted by Mike Savelle View Post
this a 3310-2 750 on a fast burn 350 crate motor , rebuilt carb...
Rebuilt by who? There are a lot of these old carbs, some of them just plain worn out, that get passed around for decades, and often messed with by people who have no idea what they're doing.
Is it even worth trying to save- are the throttle shafts nice and tight?
Old 08-04-2021, 01:40 PM   #12
Mike Savelle
Liked 7 Times in 5 Posts
throttle shafts were tight . replaced the accelerator pump and adjusted linkage , needle under squirter was missing . will update after we run the car .
Thanks to everyone that tried to help.
Mike Savelle is offline   Reply With Quote
Old 08-05-2021, 10:05 AM   #13
Henrys Toy
Liked 520 Times in 176 Posts
The accelerator squirter needle will cause that problem. Might not be a bad time to just go over the basic's, like making sure the throttle plate gasket is good and the phillips screws are tight. Had a customer with a new Holley carb and a "bent" accelerator pump lever (out of the box) that caused a similar stumble. Also just recheck ignition timing and if you still use the mechanical advance in the distributor, make sure its not sticking and it moves freely. MSD installs some very heavy advance springs ( MSD distributor) and that has caused stumbles and sluggish performance.
Accelerator pump discharge hole dia. should be last thing on list to tune.
Get your basic's squared away and you should be good to go!
Respectfully,
Henry Kunz 1534 H/SA
Henrys Toy is offline   Reply With Quote
