Do you think if I was to take a stock short block and install a good set of rods in it I would be able to get away with running it like that for about 100 runs. I am just trying to get the car out and get some runs on it to see if the susspension works and then have a good bullet built.
Liked 3 Times in 1 Post
Alan is correct about the rods, and while it is down, get someone to hone it with torque plates. Also, the Optispark is also a weak link, go ahead and purchase the MSD Rotor and Cap kit and this should take care of that problem!
Woodro Josey 2002 STK |
That's a thought Woodro. If you take it apart, to replace the rods, you'll have to balance it as well. But if you'll hone it with torque plates (have this done by a shop capable of doing RACE work) and get a ring package (made for Stock Eliminator) from some one like Total Seal, Childs and Albert, or Ackerly and Childs, and set the deck height, you'll get a good return on your money. Woodro can probably steer you right on a ring pack. His little LT1 whips up on my 427!
Alan Roehrich 212A G/S |
#4 | |
Not really. I'd want to pour it and bore it before I'd invest in new pistons, and it'd also get align honed. It'd need a fully prepped crank (blueprint stroked and indexed) as well. A lot more money and work.
