Liked 75 Times in 28 Posts
Seting the pinion angle in a leaf spring stocker running CalTracs. I know Calvert wants the pinion yoke down 2 to 4 degrees.
What should the operating angle of the transmission to driveshaft be? |
Liked 51 Times in 30 Posts
really not adjustable, all depends on height of pinion, should be "0" when pinion goes up under load??
Ideally, it should be the inverse of the lower angle, but if you haven't moved anything around in a Camaro, it should be fine.
Liked 237 Times in 126 Posts
Pinion angle and Caltracs has always confused me. A negative pinion angle is meant to negate axle/spring wrap under hard load, but the purpose of Caltracs is to prevent that. If you have a negative 4 degree pinion angle with Caltracs, it will remain negative 4 under load with the exception of the dime thickness racers leave as slack up front.
If I'm right, pinion angle is the relationship between the centerline of the crankshaft and the centerline of the pinion gear. It should be 0 (parallel) under load. A "nose down" pinion could wrap up to parallel with stock suspension but not with Caltracks.
#5 | |
Liked 30 Times in 16 Posts
Liked 20 Times in 15 Posts
the ? remains, except for you guys with mega $$ and a go pro camera mounted under the car to view movement...how do you know what the pinion is really doing. every car is different even if it is the same car [1 67 Camaro next to a duplicate 67 Camaro]
just because 1 guy says 4 degrees down tells you absolutely nothing. so the pinion is 4 degrees down, down from what, the ground? the difference is between the pinion and the driveshaft. if the pinion is 4 down and the shaft is 4 down, then you have 8 degrees. [and y7ou could still have 0 to 1 degrees at the tailshaft] loss of hp, and a broken U-Joint in your future. spring packs are different in stiffness. spring pads are different [most only a bit longer than housing dia. and therefore, offer very little resistance to movement]. shock position [front or rear of axle] shock stiffness [front or rear], tire size and width, tire pressure, launch RPM and launch hp,track traction and probably several more things cause pinion angle to change at launch. and how long will it stay. all in all, be careful about making general statement about someone elses pinion angle. Rod in AZ |
Liked 466 Times in 61 Posts
Driveshaft/pinion operating angles explained and illustrated.
https://markwilliams.com/driveshafttech.html |
