#1 | |
Liked 148 Times in 54 Posts
Thank you for your math on the v8 engine offset. The initial wrist pin offset was to make engines quieter in early days, that particilar offset was the opposite of centerline direction that the offset used to gain leverage and ultimately Horsepower. It's always been a gray area and until someone comes forward with "they've been bounced for this, then anything goes in my opinion. Last edited by MoJo Risen; 08-27-2021 at 04:52 PM. |
#2 | |
Liked 231 Times in 107 Posts
#3 | |
Why isn't the stock offset listest in accepted pistion? |
Probably because it might not be a checking point now. Not sure. Need to ask Tech. Back in 1972 you couldn't run replacment pistons. Had to run OEM.
#5 | |
Why isn't the stock offset listed in accepted pistons? |
Liked 2,493 Times in 700 Posts
Pin offset is no longer an issue that Tech is concerned.
Liked 927 Times in 263 Posts
It ain't 1972 anymore.
Liked 216 Times in 77 Posts
David Frieburger (might be spelled wrong) from Hot Rod magazine, engine masters, road kill ect ect. Just posted within the last couple of days that they tried the reverse piston trick on a 360. They saw no changes on the Dyno.
Liked 54 Times in 33 Posts
