#11 | |
Liked 125 Times in 47 Posts
Why isn't the stock offset listest in accepted pistion? |
#12 |
Liked 230 Times in 106 Posts
Probably because it might not be a checking point now. Not sure. Need to ask Tech. Back in 1972 you couldn't run replacment pistons. Had to run OEM.
#13 | |
Why isn't the stock offset listed in accepted pistons? |
#14 |
Liked 2,472 Times in 696 Posts
Pin offset is no longer an issue that Tech is concerned.
#15 |
Liked 919 Times in 258 Posts
It ain't 1972 anymore.
#16 |
Liked 216 Times in 77 Posts
David Frieburger (might be spelled wrong) from Hot Rod magazine, engine masters, road kill ect ect. Just posted within the last couple of days that they tried the reverse piston trick on a 360. They saw no changes on the Dyno.
#17 |
#18 |
Liked 225 Times in 136 Posts
I now for a fact on the Boss 302 it was worth 10 hp as I was at Dyno the night we run it.
#19 | |
Liked 733 Times in 384 Posts
Ralph, Do you happen to know how much offset that piston has? Bore = 4.0 Stroke = 3.0 Rod Length = 5.155 Wrist Pin Offset = 0.06 Actual Piston Stroke 3.00022203042 Cylinder Volume 37.701902 CI 617.823481 cc Engine Size 301.615216 CI 4942.587850 cc Crank Angle Piston TDC -0.51657300450 Piston BDC 179.05939775907 Stan |
#20 |
