Liked 705 Times in 219 Posts
In light of all this study of the laws of physics, what does the installation of an offset pin piston have on piston to valve clearance ? Sounds like a way to close up excessive clearance on one valve while opening it up on others. Or, like so many things out there, is it significant or just one more gnat to swat at?
#2 | |
Liked 734 Times in 385 Posts
Within a normal range of piston pin offset the piston travel curve does not change very much from centered. So if you are using piston TDC there should be almost no difference in VTP clearance because of wrist pin offset. Stan PS Above I am talking about if you degree the cam. If someone just installs the cam dot to dot (crank rod journal TDC?) There will be more of a change in VTP clearance from the offset over centered pin. Stan Last edited by Stan Weiss; 09-02-2021 at 11:09 AM. Reason: Added PS |
#3 | |
Liked 142 Times in 51 Posts
I believe it slows the piston down more at top of cylinder helping capture more usefule cylinder pressure. There are many different functional aspects of using offset Piston pins. Maybe this is a competition eliminator question since anything goes just as like STOCK Eliminator Piston pin offsets. |
