Liked 11 Times in 5 Posts
I know Jesel and T&D are the preferred setup and some use Crower, but I'm curious if anyone has used the Scorpion Shaft Rockers. If so, how did they hold up ? What kinda spring pressures were you using ? Thanks
Liked 125 Times in 59 Posts
I don't have experience with Scorpion I just wanted to offer a couple alternatives. Look at LGM and Harland Sharp also.
Liked 4 Times in 3 Posts
I tried to run the scorpion--- but returned them thru Summit---there was a design/Mfg. flaw---Trying to remember but I think it was the center hole over the top of the head bolts that was the problem--it was counter bored so deep and then the clearance machining over the top of the head bolts left only about 3-4 threads left----I called Scorpion and spoke with the engineer they were aware of the problem and supposedly were changing mounting bars but this was going to take 6mo. probably wanted to use up existing inventory----no other problems with them other than that---that was in 2018 so probably fixed by now---I ended up running LGM no complaints other than they sent me 1.6 Intakes instead of the 1.7 I had ordered----I only run 560# open
Liked 19 Times in 17 Posts
I have run them since 2014 with no major issues. I had a couple rockers the roller tips had some dark spots appear. Called them and they replaced all 16 rockers at no cost. This was around 2017. I honestly can't say anything negative about their customer service. I ordered an extra intake and exhaust rocker set recently and it was on my front porch in 4 days. I run about 900 open pressure.
