Old 10-01-2021, 03:18 AM   #8
GarysZ24
GarysZ24's Avatar
Liked 256 Times in 103 Posts
Default Re: New FWD weight breaks!
Now I see what they did. Instead of adding a class, they shifted the weight breaks to close up the gap between the old D & E ......E stays the same.
Billy, You'll probably have to run in C (the old D)
Gary runs C , but the same index.
They just need a new index for the new D
OLD breaks:
AAF/S 11.00 lbs/hp 13.50 13.50 8.54 8.54
AF/S 13.00 lbs/hp 13.85 13.85 8.74 8.74
BF/S 16.00 lbs/hp 14.65 14.65 9.17 9.17
CF/S 17.50 lbs/hp 15.15 15.15 9.45 9.45
DF/S 19.00 lbs/hp 15.60 15.60 9.86 9.86
EF/S 25.00 lbs/hp 17.45 17.45 10.82 10.82
Am I missing something ?
If I understand you correctly Mark, the new CF/S will have the old (current) DF/S index of 15.60? If that's the case, then changing four letters on "Shark Bait" (plus my class designation here), will be fine by me, and probably Billy's car as well.
Gary Hampton
'86 Z24,173 V6
CF/S #5824 (#78 in 2021)
Last edited by GarysZ24; 10-01-2021 at 03:23 AM. Reason: I left a letter change out, the one here.
