Old 10-10-2021, 07:05 PM   #1
jamie2370
Liked 239 Times in 90 Posts
Default quadrajet question
How far off would a top shelf carb for a 350/255/280 69 camaro be when put on 81 malibu 305/155/232.
jamie2370 is offline   Reply With Quote
Old 10-11-2021, 12:18 PM   #2
nhramnl
Liked 358 Times in 83 Posts
Default Re: quadrajet question
I have a Deano's Quadrajet (built from a new core) that has never been installed, that was built for a 305 Super Stock motor. Dean built it with specific instructions to calibrate it on the lean end of the richness scale, so that it could be used as a "bad air" carb. Based on that, I think it would be almost perfect for a 305 stocker. PM me if you're interested. I'll treat you right.
Old 10-11-2021, 06:14 PM   #3
Peter Noriega
Is that carb new or used and how much do you do you want.
Peter Noriega is offline   Reply With Quote
Old 10-11-2021, 06:25 PM   #4
Peter Noriega
Old 10-11-2021, 08:06 PM   #5
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Talking Re: quadrajet question
Peter, get the COVID out of your ears! He said "
I have a Deano's Quadrajet (built from a new core) that has never been installed". Call him! Jim
Old 10-11-2021, 08:19 PM   #6
James Perrone
Liked 1,842 Times in 429 Posts
Bolt of on and try it.
It’ QJet . No 2 carbs are the same.
Good carb is a good carb ...
james perrone 1290 STK
Old 10-11-2021, 08:47 PM   #7
GTX JOHN
I have several Edelbrock Perf. Quadrajets = New and used
I put one on my National Record Holder Dodge Truck a
few years back with no changes except rods.
It ran within 2 Hundreds of my best pro modified piece.
The are legal since they quit running numbers and just measure
them now = as long as the right size in dimensions!
John Irving
741 Stock
741 Super Stock
Old 10-12-2021, 05:08 PM   #8
Monte Howard
Monte Howard's Avatar
Liked 71 Times in 23 Posts
Yes it should be very close to a 255/350. But it depends on what air they were in the last time they ran the car compared to the air you are going to try it in. If that carb was last ran in July and you are going to try it in October, it could be a little on the lean side.’
Monte Howard 3209 STK, 3208 SS
Monte Howard is offline   Reply With Quote
Old 10-13-2021, 01:02 PM   #9
Hacksaw
Liked 312 Times in 175 Posts
It won't be far off at all. I would try it and tune it as is then I would take out two on the main jet and try that.
Old 10-14-2021, 11:37 AM   #10
nhramnl
The Q-Jet I had available has been sold. Thanks to everybody who expressed interest.
