Old 10-19-2021, 10:46 AM   #1
Tatr
Tatr's Avatar
Liked 4 Times in 4 Posts
I won the 1999 NHRA division 2 points meet @atlanta ga. Ran an old worn engine 6x 400 but still did ok. Ran the div2 national open in Montgomery Ala.don’t remember which year. Tried to get gt/ha record of 10.25 ,best it would run was 10.261, close but no cigar. Ran IHRA national event @ darlington SC,IHRA Divisonal &farmington nc (runner up). , IHRA Carolina dragway sc. (runner up). Hard to remember Dates of all races I entered, getting old and forgetful. Bruce Campbell former 2704 S/SS
Tatr is offline   Reply With Quote
Old 10-19-2021, 11:09 AM   #2
Stan Weiss
Stan Weiss's Avatar
Liked 733 Times in 384 Posts
Bruce,
What RPM were you turning with the 6x 400? I would be interested in any other information about the engine you might be willing to share.
Thanks
Stan
Old 10-19-2021, 12:11 PM   #3
oldskool
oldskool's Avatar
Liked 747 Times in 362 Posts
Here he is at Rockingham in '01, listed as driving an '82 Bird @ #8, with a 10.336.
https://www.dragracecentral.com/DRCStory.asp?ID=37286
Couldn't find any of the div races mentioned. Back in those days, I don't think DRC had results for all the div races.
But hey, Bruce is on the DRC map !
Old 10-19-2021, 03:31 PM   #4
Tatr
Tatr's Avatar
Stan, Used to turn it 1-2 shift 6600, 2-3 shift 7000,7600 + thru the traps 1/4 mile .Was hard to due with stock block. Had to due a lot of buttom end work to keep oil in the pan. Also had junk heads back then, non welded exhaust, no intake epoxy.we did it all without a Dyno. Now have access to a dyno,but too old to start over again. With all the new stuff (technology) you could make the 400 combo fly. Bruce Campbell. Former 2704 S/SS
Old 10-19-2021, 03:34 PM   #5
Tatr
Tatr's Avatar
Stan, Used to turn it 1-2 shift 6600, 2-3 shift 7000,7600 + thru the traps 1/4 mile .Was hard to due with stock block. Had to due a lot of buttom end work to keep oil in the pan. Also had junk heads back then, non welded exhaust, no intake epoxy.we did it all without a Dyno. Now have access to a dyno,but too old to start over again. With all the new stuff (technology) you could make the 400 combo fly. There’s a picture of it on autoimagery Bristol 2001? Can’t seem to be able to post it. Bruce Campbell. Former 2704 S/SS
Old 10-19-2021, 03:38 PM   #6
Tatr
Tatr's Avatar
Stan, Used to turn it 1-2 shift 6600, 2-3 shift 7000,7600 + thru the traps 1/4 mile .Was hard to due with stock block. Had to due a lot of buttom end work to keep oil in the pan. Also had junk heads back then, non welded exhaust, no intake epoxy.we did it all without a Dyno. Now have access to a dyno,but too old to start over again. With all the new stuff (technology) you could make the 400 combo fly. There’s a picture of it on autoimagery Bristol 2001Bruce Campbell. Former 2704 S/SS
Old 10-20-2021, 01:38 PM   #7
Stan Weiss
Stan Weiss's Avatar
Bruce,
Thank you for sharing that information.
Stan
