Old 11-04-2021, 07:50 PM   #1
Bill Bogues
Bill Bogues's Avatar
Liked 169 Times in 53 Posts
Smile Re: Pump gas in stock
yeah, but every little bit helps.....make a difference to people just barely hanging on.
Bill Bogues 4696 STK
Bill Bogues is offline   Reply With Quote
Old 11-04-2021, 08:12 PM   #2
SDT1DYI
Liked 455 Times in 147 Posts
Default Re: Pump gas in stock
C11 is now 17.00 $ a gallon . At a Divisonal double, with 3 TNTs 3-4 Qs runs and going 2-4 E runs
The difference between running C11 and pump gas could be as much as 150 00$ or more. Times 6-8 Divisonals and some National events, saving could over 1K annually.
Not a small number for some...
SDT1DYI is offline   Reply With Quote
Old 11-04-2021, 08:18 PM   #3
Only thing I could think of is they (being NHRA tech ) could pick up a sample from the nearest let's say Shell station. Yours would have to look the same at fuel check. They're not gonna do it but maybe this will get them.
NHRA, are you listening ? Shell Oil shakedown!
Old 11-04-2021, 09:58 PM   #4
Dave Gantz
Liked 251 Times in 125 Posts
Good idea. Like you said though, NHRA has no motivation to do so. If it ain't their idea, it ain't a good idea.
Old 11-04-2021, 11:10 PM   #5
SST3193
Liked 2 Times in 2 Posts
Friend raced carts and they all brought fuel, it all went into the same big container. Everyone run that same fuel and whatever else was put in that fuel tanker. Certainly Sunoco ( or Whoever) would love to be seen dispensing fuel from a pretty fuel tanker.
Some deal along those lines could work but, OHHHH the bitchin’!
SST3193 is offline   Reply With Quote
Old 11-05-2021, 08:50 AM   #6
Billy Nees
Liked 7,762 Times in 1,741 Posts
Now something like "everyone run that same fuel" would/could be interesting but..............
who gets to pick the fuel and is it always the same fuel. My stuff acts differently and wants different tune-ups on different fuels. Not to mention, a 396/375 is going to want a "hotter" fuel than a 6 cyl. Nova and that 6 cyl. Nova isn't going to run as well on the fuel that a 396/375 would need to live.
Billy Nees 1188 STK, SS
Old 11-05-2021, 09:38 AM   #7
Signman
Liked 269 Times in 99 Posts
I get this discussion is about making pump gas legal but NHRA fuel test fails oxygenate additives and they don't seem interested in a better device.
A few years back VP was promoting C9 which is high octane unleaded gasoline with no additives. 100% gasoline no oxygenates. It was marketed to circle track who had embraced it and Stock Eliminator. At the time was looking at fuels and asking questions while building a good engine.
NO it was not as fast as C11 but it did not have any of the corrosive additives. Could still run a second under the tuneup developing had good potential to go rounds plus it is lower cost. Won class at a national event with it which netted some help from VP in product and tech.
NHRA removed C9 and a Sunoco equivalent from the accepted fuel list because it did not test consistently national event to national event plus NO ONE WAS RUNNING IT! Very few racers would be affected.
In division one the only other person I met who admitted using it was a small inch heavy upper class racer. He had similar results and liked it for similar reasons. Trying to help promote the fuel over the few years it was on the list the question always was IS IT FASTER of course the answer was no so off to the C11 drum they went.
Old 11-06-2021, 10:08 AM   #8
Rsmith38
Liked 28 Times in 15 Posts
I was using C9 when I was #1 Qualifier at Epping in R/SA. The next year at the epping natinal at fuel check they said C9 is not on the approved list? Took 2 weeks before Brian got back to me and said no one was using it??? Had to switch to C10. Us little Guys don't count!!!
1051 Q/SA
Rsmith38 is offline   Reply With Quote
Old 11-06-2021, 12:40 PM   #9
Glenn Briglio
Glenn Briglio's Avatar
Liked 972 Times in 309 Posts
Pm sent
Old 11-05-2021, 10:28 PM   #10
Dave Gantz
If everyone brought their own fuel to NHRA races, and it was all dumped into one container; the explosion could be seen from outer space!
