#1 | |
Liked 497 Times in 243 Posts
Advantage/Disadvantage, Bypass/Deadhead regulator?
I see Weldon leans toward Deadhead, but they sell both... This is carbureted if it matters. I've never tried a Bypass set up, except with fuel injected stuff with mechanical pump. |
You set the dead head around 5-7#s. The pump has its bypass on the pump. I run the pump at 21-23#s Works great. Very steady pressure and more volume than you will ever need
I think the advantage to this set up would be you only have to run a short hose from the pump back to the Tank
KEITH MAYERS 2-1/2 X somebody Still many X nobody Last edited by Keith 944; 11-05-2021 at 06:38 PM. |
Liked 883 Times in 237 Posts
If you are running a QJet or any other non Holley OEM carb the bypass style is the way to go.
Liked 880 Times in 311 Posts
What about the BG rebuild or freshen. I've got 2 that have been sitting dry since 2010 when I parked everything.. Any parts out there for seals and rubber parts? Hate to buy new if I can use them.. working well when parked.
Adger Smith (Former SS) |
#6 | |
Liked 226 Times in 76 Posts
I would think that even if someone doesn't sell the specific pn's for your BG pumps, you get some replacement ones from McMaster or a similar online seal outfit with some time using calipers to measure what you need. I have never had BG pumps apart though, so I could be off base on what the seals and rubber parts look like though...
Andy Friar |
Liked 348 Times in 152 Posts
Adger, I believe I've seen seal kits on racejunk for cheap money, I want to say $12.95. Worth a peek.
Phil Molski PMR Performance S/C 1623 |
Liked 133 Times in 76 Posts
Ninja Fuel Systems sells rebuild parts for BG pumps and regulators. You can find him on FB or ebay. I believe Quick Fuel has the designs from BG and their parts interchange, I know the fuel filter elements will fit BG.
Liked 54 Times in 33 Posts
Montieth always ran his Hatari Qjet dead head. It was set up that way when I got the car so I tried and it worked flawlessly. Didn't see a reason to change. Ran at 6, 7 lbs.
#10 | |
Technology and product advancements provided us with the options now available and having the return line is one of them ,especially with the newer high volume /pressure pumps that have flooded the market.
