Old 11-06-2021, 07:43 PM   #1
Jeff 2023
Default Re: Front wheel with more than 2 1/4" backspace
Also check out Holeshot wheels. I think they make 1 front wheel with up to 2 and 7/8 offset . Probably a 15x4 though
Jeff 2023 is online now   Reply With Quote
Old 11-08-2021, 08:40 AM   #2
dragracerray
dragracerray's Avatar
Liked 210 Times in 91 Posts
SSDiv6 (I wish I knew your name) thanks for the tip. I will get in contact with them.
Jeff you are right Holshot makes a bigger backspace but the wheel is wider. I am trying to move the wheel towards the motor to get more clearance with the inner fender well. So a wider wheel with bigger backspace doesn' t help my problem.
thank you for the help. Ray
Ray Bassett
I/SA 1687, SS/DA 1687
"SuperPro is both", unknown
dragracerray is offline   Reply With Quote
Old 11-08-2021, 02:46 PM   #3
SSDiv6
Talking Re: Front wheel with more than 2 1/4" backspace
My name is Joe and I am not the Brandon/Joe.
If you call Bogart, try to reach Ricky and explain the situation and let him know the type of front brakes you are using. He is a wealth of knowledge and information as regards to drag racing wheels.
Old 11-08-2021, 04:11 PM   #4
Mike Gray
Mike Gray's Avatar
Liked 699 Times in 202 Posts
Jegs has a Racestar wheel with a little over 2 1/2 back space
63-Series Pro Forged Wheel
Size: 15" x 3.5"
Bolt Circle: 5 x 4.75"
Back Spacing: 2.55"
Offset: +13.7 mm
Finish: Polished
Features:
Old 11-08-2021, 06:29 PM   #5
dragracerray
Thank Mike. You are better at finding wheels on Jeg's than I am. I spent a lot of time on the Jeg's site but could not make the filters work. You would think when you were shopping for a wheel there would be filters,
1. wheel diameter
2. wheel width
3. wheel backspace
All Jeg's gives you is bolt pattern and backspace! No wheel diameter or width filter even exists!
This is a good option Mike. Thanks! Ray
https://www.jegs.com/i/Race-Star-Whe...7252P/10002/-1
Ray Bassett
Old 11-08-2021, 09:44 PM   #6
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
I have a 71 with a 28 in. frt tire with 1 3/4 BS. Bogart,no clearance problems.Do you know anyone that has a 2.25 BS rim that you can try,it should work even with a 28 in.tire.If not somethings not right on how far the rotor/caliper sets outward...gsa612
Old 11-09-2021, 01:37 PM   #7
dragracerray
G/SA I wish I knew your name. Your example made me dig deeper. We use the same inner fender well (1971 and 1980 are the same). So it is essentially the same car. I removed the wheel and made a bunch of measurements. I thought I have a 3.5" wide wheel. It is 4.5" wheel. So if I buy a 3.5" wheel that moves the center of the wheel in 0.5" right there. On top of this my Weld Wheel is a 1 7/16" backspace, not 1.75" like I thought. So I think your 3.5" wheel with 1.75" backspace moves the tire in about 13/16". I think that works even on paper. Thanks for taking the time to reply and get me off my behind. Ray
By the way I use Strange brakes. The rotors space the wheel out about 1/4"
Ray Bassett
Old 11-10-2021, 02:37 PM   #8
Mike Gray
Mike Gray's Avatar
1. wheel diameter
2. wheel width
3. wheel backspace
Oh oh, the add may have a type-o, I see 2 different back space numbers on the site.
2.55 and 2.25
Old 11-14-2021, 11:50 AM   #9
dragracerray
John lights vary from a little red to a little green. You are right that is why I want a bigger tire. More "green" reaction time and improved ET to boot! Gotta take the "win-win" when you can get them. There aren't many in this sport
By the way I have 15x4 wheels, not 15x4.5. Weld makes a wheel that matches the rear with more backspace. This moves the wheel towards the center of the car by about 1".
https://www.jegs.com/i/Weld-Racing/9...54344/10002/-1
thanks again for the help.
Ray
Ray Bassett
