#1 | |
Liked 184 Times in 113 Posts
Having a fight with Pat Cvengros over this RIGHT NOW ! Dan Where did you get that information from? I disagree since it clearly has a distributor with a single coil. Pat Cvengros - Pacific Division Technical Director (626) 250-2295 ---------------------------------------------------- My response !!!!! Found out mine is considered a Distributorless System So a Crank Trigger is fine.. D ---------------------------------------------------- Previous Conversation; No, crank trigger ignition systems are only permitted on distributorless ignition systems. If you switched to Super Stock you could run a crank trigger with the Opti spark distributor. Pat Cvengros Pacific Division Technical Director Pat thinks the Opti s not a Distributorless system ! So I am confused. Needs some help here !! Dan Last edited by Dan Fahey; 11-10-2021 at 01:14 PM. |
Follow up EMAIL from Pat !!
Dan, Unless you have documentation from Chevrolet stating it is a distributorless system it’s not; so a crank trigger would not be legal. 1. Distributor: a device in a gasoline engine for passing electric current to each spark plug in turn. Pretty clear to me you don’t have a distributorless system. ======================== SO I am confused Just sent Pat KRATLIF's response. Pat's response is below. Dan Thanks for the heads up, we will have to look this weekend at Pomona. As I mentioned previously, unless you have documentation from Chevrolet stating it is a distributorless system it is not. Pat Cvengros Pacific Division Technical Director (626) 250-2295 Then sent GUMPS response... Pat Responded You can believe who ever you want, I’ve answered your question based on how NHRA officials interpret the rulebook. Crank triggers are not a legal option for the Opti Spark. Pat Cvengros Last edited by Dan Fahey; 11-10-2021 at 02:03 PM. |
#3 | |
If enforced under this interpretation, this would park pretty much every LT car running Stock Eliminator! I'm pretty sure that Holley doesn't have a harness. I don't know about the other systems. Keep being AWSOME Dan!! |
Liked 314 Times in 177 Posts
Hard to put the worms back in the can after it's opened. Good going Dan !
#5 | |
Out did Billy Nees today !! Not a Dodge Manifold. Did manage to squeeze Tomato paste out of a Rock !! D |
You continue to make friends every where you go! Lmao
Liked 7,916 Times in 1,757 Posts
Not even close Dan. all you have done is start a conversation that doesn't need to be had.
Where does the OEM optispark pick up it's signal? From the crankshaft? Then it's a "crank trigger" system. IMHO, (and I'll probably catch some heat for this) any OEM ignition system that uses a crank sensor and a cam sensor to sort out the timing events should be able to use an aftermarket type crank trigger system.
Liked 8 Times in 3 Posts
A crank trigger is nothing more than a crank sensor, the LT1 came factory with a crank sensor and nowhere in the rulebook says you cant use aftermarket sensors.
#9 | |
Then you better have that conversation with Pat Cvengros! What we say does not count if he believes otherwise. These are not our rules ! Pat is the arbiter not us ! Read the exchange…. I ran into the limits of the OBD1 PCM. Sought advice from people more experienced than I. The 8.3 rule was confusing comparing available products out there. So contacted a Technical Director. The feedback from CR is in conflict with what Pat said. So before proceeding over the rulings cliff. I want clarification ! Wouldn’t you? D Last edited by Dan Fahey; 11-11-2021 at 11:58 AM. |
Dan, the LT-1s that I am dealing with use a Holley PCU wired into the opti-spark! How can that be illegal?
