Old 11-10-2021, 04:45 PM   #1
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Re: TorqueHead vs Opti
Originally Posted by GUMP View Post
So what you are saying is that you just rocked a boat that was on calm seas....!!!
If enforced under this interpretation, this would park pretty much every LT car running Stock Eliminator!
I'm pretty sure that Holley doesn't have a harness.
I don't know about the other systems.
Keep being AWSOME Dan!!
Y E A uh !
Out did Billy Nees today !!
Not a Dodge Manifold.
Did manage to squeeze Tomato paste out of a Rock !!
D
Old 11-10-2021, 05:27 PM   #2
Keith 944
Keith 944's Avatar
You continue to make friends every where you go! Lmao
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 11-11-2021, 08:32 AM   #3
Billy Nees
Liked 7,891 Times in 1,753 Posts
Not even close Dan. all you have done is start a conversation that doesn't need to be had.
Where does the OEM optispark pick up it's signal? From the crankshaft? Then it's a "crank trigger" system.
IMHO, (and I'll probably catch some heat for this) any OEM ignition system that uses a crank sensor and a cam sensor to sort out the timing events should be able to use an aftermarket type crank trigger system.
Billy Nees 1188 STK, SS
