Old 11-13-2021, 07:14 PM   #41
RJ Sledge
Liked 291 Times in 92 Posts
Default Re: TorqueHead vs Opti
....and whom are you referring too...?
RJ
RJ Sledge is offline   Reply With Quote
Old 11-13-2021, 10:12 PM   #42
SSDiv6
Originally Posted by Adger Smith View Post
When did Pat become the National Tech director?
Sometimes it takes a long hard look at the wording and punctuation of the rule &
understanding the function of the factory systems
I would to go to the top to get the correct/final answer
Every time I am at a standstill with the Glendora office, I reach out to the Tim White, NHRA's Senior Director Of Engineering.
Tim worked for Delphi, Cummins and Penske Racing prior to joining NHRA. I have always enjoyed the technical subject conversations that have taken place with Tim and he has always backed up his responses with an email.
Old 11-15-2021, 11:22 AM   #43
GUMP
Liked 2,359 Times in 557 Posts
The part numbers for the LT1 crank sensor.
12552427 Timing Cover
10190917 Reluctor Wheel
19170837 Crank Sensor
I have forwarded this to Pat for his consideration.
Old 11-15-2021, 06:18 PM   #44
Mark Lewis
Liked 208 Times in 45 Posts
I got a call from Pat wanting to know if I ran a crank trigger, supposedly called several other racers wanting to know the same.
Time will tell what will happen. thanks Dan,
Mark Lewis is offline   Reply With Quote
Old 11-15-2021, 06:32 PM   #45
Bill Moulding
Bill Moulding is offline   Reply With Quote
Old 11-15-2021, 11:04 PM   #46
Jim Whitehead
Liked 150 Times in 41 Posts
Pat called me today.
Jim Whitehead is offline   Reply With Quote
Old 11-16-2021, 12:44 AM   #47
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
One way or another the vagueness in the rule will be written with clarity.
NHRA does it all the time.
Stock Eliminator does not lend well with the aftermarket industry.
Should be some sort of rule allowing bolt on upgrades.
Crate Motor offered some of that.
Like allowing under used engines such as big Caddy engines in BOP cars.
Bolt on 4bbls like on the mid70/80 Mustangs and Monzas.
Under used Ford 300cuin 6 with a 4bbl.
Or for that matter let the 6 cylinder AMC guys have the better heads.
Or flattop Pistons for the Low compression BOP cars.
74 Firebird with 10:1 compression would be a A stocker.
Much like Pure Stock Drags and FAST do.
Just my 2 cents
Old 11-16-2021, 01:14 AM   #48
Bill Grubbs
Liked 564 Times in 66 Posts
Just my 2 cents
Dan, Please go race Crate Motor. Numerous people have tried to help you. You just don’t seem to be very receptive.
Bill
Bill Grubbs is offline   Reply With Quote
Old 11-16-2021, 01:55 AM   #49
Adger Smith
Liked 880 Times in 311 Posts
What will Dan get for Christmas?
Adger Smith (Former SS)
Old 11-16-2021, 09:45 AM   #50
dean ribeiro
Liked 239 Times in 79 Posts
Originally Posted by GUMP View Post
It is very clear that you are "not real smart".
My first post in this thread was an attempt to point you in the right direction. You have not hurt my feelings. You have wasted a bunch of my time responding to phone calls about this.
From here on out you are on your own.
See you on the bottom of the qualifying sheets,
Daren
Unfortunately, common sense is a flower that does not grow on every tree!
dean ribeiro is offline   Reply With Quote
