Liked 10,822 Times in 2,250 Posts
It’s our thread! It a discussion on how we would like, racing, to be. Most if not all power’s that be look at CR, SRAC, NHRA, manufacturers, sponsors, racers, and host of others. Everyone wants racing to be fair and fun!
Just a heads-up, NHRA 2022 Rule Book, General Regulations, Sections 9;1, 9;2, 9;11. Read it yourself and decide what's legal.
You can download the whole book by clicking on NHRA Competition and clicking on Rules 2022 Rule Book. Read it and decide for yourself.
Liked 1,604 Times in 583 Posts
9:1 COMPUTER
A computer is defined as any device (electrical, mechanical, pneumatic, hydraulic, etc.) that activates any function of, or in any way affects the operation of, the vehicle based on measurement, sensing, processing, etc. of any data related to the performance of the vehicle. Except those installed on stock vehicles by the new-vehicle manufacturer for the proper operation of such vehicle, no vehicles may be equipped with computers. Per Class Requirements, OEM or aftermarket OEM-type electronic fuel injection permitted. Electronic fuel injection must be closed, OEM-type system; i.e., may monitor only engine functions. Monitoring of vehicle performance criteria, wheel speed, driveshaft speed, vehicle acceleration, etc. by fuel-injection system prohibited. Any form of torque management (e.g., launch control, traction control, height ignition correction, etc.) is prohibited. All related wiring, sensors, etc. must be identifiable to the tech inspector. See General Regulations 9:11 TRACTION CONTROL. During NHRA competition, a portable computer (e.g., laptop, PDA, Palm Pilot, programmer, etc.) must be securely mounted when located in driver’s compartment at any point beyond the staging area ready line. All functions or values must be preset prior to this point. Per Class Requirements, timed or rpm-activated shifters and the like permitted, but all automated functions must be preset before the run. Timer may display only timer amount dialed in; analog or digital display permitted. Devices may be removed at any time at discretion of NHRA Technical Department. Last edited by SSDiv6; 12-29-2021 at 11:16 AM. |
9:2 DATA RECORDERS
Data recorders may be used (per Class Requirements) to record functions of a vehicle so long as they do not activate any function on the vehicle. All data recorders manufactured after Jan. 1, 2006, must be NHRA-accepted. A current list of NHRA- accepted data recorders is available on NHRARacer.com. Fifth-wheel sensing devices prohibited on all vehicles (includes wheelie-bar wheels). All lines sensing flow, pressure, etc. of fuel or oil must be metallic or steel braided. Ride height sensors prohibited unless specifically permitted by Class Requirements. Cylinder pressure sensors prohibited in all classes. Any device (mechanical, hydraulic, pneumatic, electrical, optical, etc.) other than OEM-type that assists in determining track location of the competitor’s own vehicle or opponent’s vehicle is prohibited. Only OEM-style mirrors, mounted in conventional fashion, permitted. For non-OEM data recorder applications, the transmission or display of any vehicle performance data (e.g., wheel speed, driveshaft speed, vehicle acceleration, etc.) gathered or processed by the data recorder, to the driver or any remote location, during the run, is prohibited. This data may be reviewed (printout, replay, etc.) only after the run. Discovery of a device that displays, indicates, or transmits “on track,” “track location,” or “elapsed time”-type data will be grounds for immediate disqualification from the event, loss of all NHRA Camping World Drag Racing Series or Lucas Oil Drag Racing Series points for the season, and suspension from all NHRA Championship Drag Racing events for remainder of season. Additional penalties may be imposed at the discretion of NHRA. Devices may be removed at any time at the discretion of the NHRA Technical Department. |
Any type of traction-control device, electronic or mechanical, is prohibited. A traction-control device is any unit or system that uses live data to control functions of the vehicle, such as tire slip, which are not controlled by the driver. These devices are, but not limited to, timing control based on wheel, driveline, or engine acceleration, braking control, throttle control, tire-shake meters, vertical acceleration meters, misfire control, stutter box, relays, and/or rpm-activated chips. See 9:10 TELEMETRY DEVICES, 8:2 DELAY BOXES/DEVICES, 8:3 IGNITION, 9:1 COMPUTER. |
#7 | |
Guest
Posts: n/a
Liked 227 Times in 74 Posts
In 9:1 under computer
It says no vehicles may be equipped with computers. Then in the paragraph below that it says During NHRA competition, a portable computer (e.g., laptop, PDA, Palm Pilot, programmer, etc.) must be securely mounted when located in driver’s compartment at any point beyond the staging area ready line. All functions or values must be preset prior to this point. Kinda contradicts it self. LOL
James Boyce 6052 K/SA Stock National record holder 2015,2018,2 times in 2022,2023 |
Liked 237 Times in 126 Posts
The point is the driver drives the car. Your foot controls fuel flow. No device takes over and regulates the flow of fuel for you. Modern efi cars come with stuff like that from the factory. My S/SS friends with efi cars talk about fuel curves and I'm stuck with a 4150 even in SS Modified.
The boxes that drive for you are not "data loggers" data loggers record stuff to be read in the pits to improve that guesswork called racing. On the topic of rule roll back, FWD conversion cars have no place in SS/GT or Modified. LS motors come in RWD cars and should not be allowed in FWD vehicles.There is just something wrong about a classic Nova staging against a Cobalt and being given the head start... Put them all in Altered
Dale Shearon 68 Mustang 6394 Last edited by FireSale; 12-29-2021 at 12:44 PM. Reason: messed up |
