Old 01-12-2022, 09:29 AM   #1
stock1080
Liked 94 Times in 38 Posts
Default mirror cover
What is the best way to cover the hole from a outside door mirror? Thanks for your time
stock1080 is offline   Reply With Quote
Old 01-12-2022, 10:01 AM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Default Re: mirror cover
There are various ways to accomplish it depending on the size and shape of the opening .
One method I use is take a piece of .090 aluminum shaped to cover the opening and weld an aluminum stud to the backside . . the .090 is just thick enough that you can put a nice bevel on the edge for a nice appearance.
I've also attached them with 3M panel bonder..
Old 01-12-2022, 10:43 AM   #3
Adger Smith
Liked 880 Times in 311 Posts
I used the little push in chrome plugs that you can pick up at home depot and Lowes in the Hardware Dept. I think they were a Hillman brand and fit the round hole in the door.
Adger Smith (Former SS)
Old 01-12-2022, 11:25 AM   #4
J&S Racing
Liked 319 Times in 82 Posts
Old 01-12-2022, 09:45 PM   #5
Rob Petrie E395
Liked 216 Times in 77 Posts
Originally Posted by J&S Racing View Post
That looks nice. Who makes them?
Old 01-12-2022, 10:29 PM   #6
J&S Racing
Those were my 1st attempt….I just used a scrap piece or carbon roll bar tube and cut them to fit the original mirror gasket. I went back and re did them with a flat piece of carbon.. Still need to find a better screw.
Old 01-13-2022, 10:28 AM   #7
stock1080
thanks to all, I'll let you know how i make out. Cheers
Old 01-13-2022, 01:53 PM   #8
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
I machined something like that out of scrap aluminum for my Mustang and fastened it with studs to the stock door holes. I can add a mirror if I need one without removing anything. Yours is nicer, BTW.
Dale Shearon
68 Mustang 6394
Old 01-13-2022, 02:45 PM   #9
FED 387
Liked 333 Times in 180 Posts
----LOOKS terrific----you might try a BLACK chrome button head screw---looks better than a Phillips screw plus it won't rust---FED 387
