Old 01-16-2022, 11:25 AM   #4
jmcarter
jmcarter's Avatar
Liked 3,184 Times in 973 Posts
Default Re: Getting into Indy
Just be aware that unless you can run significantly under your index you’ll get your qualifying runs plus first round of class [unless of course bad weather prevents class from happening (knock on wood because Indy Class is the best there is)] and then you’ll be spectating from that point. You can search history but there have been some very fast spectators because they had a issue during one of the “good” sessions. If they should shelve AHFS for Indy again then you better bring a one second under car. Nothing wrong with going with a slower car for the experience, just saying.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
