Old 01-27-2022, 08:41 PM   #1
Tom Meyer
Liked 354 Times in 120 Posts
Default Re: Where is it legal to add ballast?
The requirement that the 1/2" bolts for permanent ballast be welded but the 1/2" bolts for the removable ballast can remain unwelded is probably not specifically for safety. It's probably more about honesty. And I don't think we are talking about welding the bolts so hard that they get cherry red. A little spot weld or a small amount of braze has passed tech all the time.
_Or an nice bead of silicon covered with a quick coat of paint. Just joking.
Tom Meyer 5240 SS Stock ???
Old 01-28-2022, 12:13 AM   #2
older racer
Liked 68 Times in 26 Posts
at end of track? woodburn?? lol
older racer is offline   Reply With Quote
Old 01-28-2022, 09:32 AM   #3
SSDiv6
There are two narratives to adding weight to a racer car:
  1. You add or remove weight to just change classes without caring about the effect on the suspension and percentage of rise.
  2. You add or remove weight to change classes, from specific locations, knowing how it will affect the suspension and percentage of rise.
As others stated, if you ever have an opportunity, scale the car and check the instant center and variations by placing weight for different classes at various locations and document your findings.
