Liked 150 Times in 41 Posts
Mike like I said if the O2 is way back in the collector you wont see a reading unless under extreme load. Try putting up on the converter 3,000-3300. You may see it read then.
Liked 66 Times in 31 Posts
Taking your advice Jim and buying an XFI. I don't see that I have an alternative.
I got my new XFI and I don't see a connector for the MSD distributer. Anybody know the solution to this problem?
So I downloaded the software from FAST on my laptop and was able to view the schematics and instructions and it's clear as mud which connector goes on which injector. Thanks FAST. Maybe it doesn't matter which injector you plug the wire into.
#5 | |
Liked 228 Times in 70 Posts
Also MSD distrubutor should be black /violet to Fast crank connector red wire and black/orange to Fast crank connector black wire. Crank trigger application would be green wire on crank trigger to red wire on fast and violet on crank trigger to black wire on fast
#6 | |
Liked 328 Times in 80 Posts
Hope this helps Ernie Neal SS 354 |
Thanks Ernie, it came with the adapter for the TPS but not the one for the Msd dist. I had to make an adapter for the dist.
So, I got my new XFI installed and now the car won't start. I'm ready to push it in the pond.
