Old 03-31-2022, 10:16 PM   #1
vette5148
Liked 44 Times in 14 Posts
Default Re: Chevy II front end alignment
I have a hunter computerized alignment system. It's an older one but still gives accurate readings. I agree with limiting travel on a Chevy II. I always run the car through the whole suspension travel to check and adjust bump steer. Caster is very important to top end stability. 2 1/2 to 3 1/2 degrees is nice but too much also makes it hard to steer. Camber settings are dependent on how much stuff changes as the suspension goes through it's travel. I watch camber change as I check the bump steer and kind of pick a spot in the middle for a setting. Everything can't be perfect for the whole run but I will raise the front a little to simulate going down the track and set the toe at zero because in or out the tire is still scrubbing. I've been doing this for over 30 years and have had pretty good luck. Just my thoughts. Thanks!
vette5148 is offline   Reply With Quote
Old 04-01-2022, 09:47 AM   #2
Doug Domm
Liked 84 Times in 21 Posts
Are you setting alignment with driver weight in the seat?
Doug Domm is offline   Reply With Quote
Old 04-01-2022, 09:31 PM   #3
vette5148
Yes. Sorry I forgot to mention that. I always put weight in the seat to simulate the driver.
