Sponsor
Liked 63 Times in 11 Posts
Thanks for the great comments!
Regardless of which system you choose I suggest you get a system the was made for racing. Products that are made for aviation, hiking, shooting, etc.. use a "standard" Density Altitude Formula. For Racing, although our cars do push through the air, they also consume it to make power. You can't look at the density as a whole. The amount of oxygen and water that make up the air's density, mixes with fuel to produce a varied amount power and therefore effects performance. In drag racing, this is what we want to measure and the "DA" we calculate is adjusted for these factors! Although this derivation from "text book" DA calculation may not seem apparent to you on any given day when conditions are stable, over time (Spring, Summer, Fall) when temperatures and humidity levels change significantly you will see the effect when trying to predict your car. Altronics patented this calculation specifically for internal combustion engines and measuring performance in our PerformAIRE weather stations. |
#2 | |
They are weather stations with logging capability. |
Liked 755 Times in 213 Posts
I’m still using my old Kestrel 4250 Racing Weather Tracker and I like his mobility and precision.
I like collecting data and depending on your racing track, some are level lower or higher than their paddock and some create a stadium form (tower and side stands). Those conditions will produce a data difference. Also take the time to check conditions after those stands. Sometime you will be surprised. |
