Old 04-11-2022, 10:22 PM   #1
mike britt
Liked 66 Times in 31 Posts
Default Turbo 350 vent
So after making 3 passes back to back I loaded the car and then I noticed drops of trans fluid where the car was parked. I finally got around to jacking it up and it appears it blew it out of the vent. Is this a common problem with a turbo 350? do I need to put a catch can on the vent?
mike britt is offline   Reply With Quote
Old 04-12-2022, 09:11 AM   #2
SSDiv6
Liked 1,583 Times in 582 Posts
Default Re: Turbo 350 vent
http://www.classracer.com/classforum...ad.php?t=40522
Old 04-12-2022, 09:46 AM   #3
garyc
Liked 51 Times in 30 Posts
you might need a larger cooler, back to back runs will sometimes overheat tranny and push fluid out vent, i used a moroso coolent overflow tank and plumb to vent, chrysler 727
garyc is offline   Reply With Quote
Old 04-12-2022, 03:41 PM   #4
mike britt
SSDiv6 that conversation went all over the place but I think I get it.
Old 04-12-2022, 05:16 PM   #5
Mike Jones
Liked 684 Times in 289 Posts
1320Racer was a colorful palette of knowledge and conversation.
Old 04-12-2022, 05:26 PM   #6
Rob Petrie E395
Liked 216 Times in 77 Posts
What ever happened to him? Haven’t seen him in here in a while.
Old 04-13-2022, 10:59 AM   #7
cad
cad's Avatar
Liked 91 Times in 51 Posts
He spends his time bashing people's ideas on the DRR forum...
Old 04-13-2022, 11:44 AM   #8
Eman
Liked 133 Times in 76 Posts
Where is the fluid level on the stick after making a pass? Do you have a temperature gauge on the trans? My T350 would puke some out if the fluid level was a little high when the trans was hot. When I say hot my pan temp was usually around 150*. When fluid level was correct it would still have a mist so I put a catch can on the vent with a clear hose. Never had much in the hose but the mist even when on the transbrake and double entered with pan at 200*.
Old 04-14-2022, 08:17 AM   #9
curtis reed
Liked 125 Times in 59 Posts
I think you just have to say his name 3 times and he will appear.
curtis reed is offline   Reply With Quote
Old 04-14-2022, 08:37 AM   #10
pmrphil
Liked 348 Times in 152 Posts
PLEASE DON'T !!!
Phil Molski
PMR Performance
S/C 1623
