Liked 653 Times in 89 Posts
1969 BBC Camaro Stocker AA/SA, A/SA, B/SA
Black interior super clean and well maintained Exterior dark green 80%,mint green strip and pink strip. Originally Arizona car unmolested perfect trunk and floor pans. Has been a race car the last 51 years. Has title. Originally owned by Les Rider (1970-1981) then Mike fuller (1982-2017). This one of the nicest/clean 1969 Camaros out there. If you’re looking for a clean BBC 69 Camaro you will not find a cleaner one. Car has been updated in the last 5 years by MPR. 10 point chrome moly cage in 2017 by MPR Following updates and New parts were done in 2020 by MPR Copo style wheelie bars New strange 35 spline axels, spool and pro gear KTRE rear end housing Strange rear brakes Strange master cylinder Rear wight bars Fuel gallon aluminum cell Re-work/update front Wildwood brakes Re-work/update front end (Tom Stiles) Re-work/update rear suspension and springs (Tom Stiles) Strange double adj shocks front and rear These Updates alone were over $15,000 Auto Meter gauges and Tach Original bucket seats Original wood steering wheel CSR water pump Magna flow fuel pump MSD ignition Turbo action shifter Elston step stainless headers Kilgore 400 trans freshened by Joel 25 runs ago ATI converter fresh 25 runs ago Bogart D10 wheels all 4 M/T radial’s rear Clark Holroyd Holley carb Engine 396/375 Steel head NHRA rated at 412 hp with Automatic Fresh zero runs. Last time car/eng was raced in B/SA trim (summer2019) @#3670 lbs it ran 10.55 -70 under index. Last time car was raced before it was parked fall of 2019 it went 10.22 at 128.5mph in AA/SA 50 lbs from A/SA min weight with Kevin Zaskowski driving it at Norwalk nationals 2019 at 3390-3405 lbs. both B/SA and AA/SA were in none class heads up mode. This engine has gone 10.20s @128mph in B/SA in class mode in a different car. Engine was original built by Darrel Wikel, Currently Maintained by Keith Lynch. Engine is currently out of the car and can be inspected Complete car $52,000 Call Chuck Downing 517-605-8309 or Paul Wong 702-281-8520 for more info. Car is located in SE Michigan
Charley Downing 3548 STK Last edited by Charley Downing; 04-05-2022 at 10:06 AM. |
Liked 57 Times in 24 Posts
Can the car be bought less motor , trans & converter
Thanks David If you only want to answer by a phone call I under stand and will call |
is this still avaiable, need to see pics please heavyduty225@bellsouth.net
thanx |
Liked 419 Times in 85 Posts
Car also available now with a fresh Aluminum Head 375/396 rated 405hp turn key for $55,000
Sold
