Old 06-14-2022, 02:11 AM   #1
Albert Lee
Liked 258 Times in 49 Posts
Default Re: Class pushed back at Indy Nats for Jegs Brackets?
Originally Posted by Dragrac419 View Post
Yes NMCA does have heads up races. The only stipulation is you can't run more than a tenth quicker that you qualified.
I believe it's no more than a
tenth quicker than the "fastest" car qualified (of the two in question).
Al Corda
Albert Lee is offline   Reply With Quote
Old 06-14-2022, 06:16 AM   #2
Chip THELEGEND Johnson
Liked 281 Times in 79 Posts
I may be wrong but I think the open comp class has a tenth breakout. You get 3 qualifying runs. They DIAL you in on your quickest run minus 1 tenth. If you run quicker then you breakout.
Chip THELEGEND Johnson is offline   Reply With Quote
