Old 04-12-2008, 02:53 PM   #1
BoydW
Default 780 Holley (LT1 carb) Setup for Super Stk
Does anyone have a name and number of anyone that is good working with Holley carbs? Looking to have my carb set up for Super Stock GT and not sure what I can do legally. One of the things I have had thoughts about is like doing away with the vacuum secondaries and putting on a progressive linkage. Talked to a couple people that set up the Rochesters Quadrajets for Super Stock, but not having luck finding someone that does the Holleys. Any info would be appreciated.
Thanks,
William S. Boyd
BoydW is offline   Reply With Quote
Old 04-12-2008, 03:14 PM   #2
Liked 1,847 Times in 418 Posts
Default Re: 780 Holley (LT1 carb) Setup for Super Stk
Thanks,
William S. Boyd
Only one, Clark Holroyd, 909-591-4320. You'll be hard pressed to find anyone to build a better Holley. The only other person I can think of is Jimmy Bridges, 615-228-3516.
Old 04-12-2008, 04:02 PM   #3
John Mason
Talking Re: 780 Holley (LT1 carb) Setup for Super Stk
See Frank Allen's for sale ad below. Just what you need.
John Mason 7743 SS
John Mason is offline   Reply With Quote
Old 04-12-2008, 04:05 PM   #4
bsa633
Banned
Clark is good..and a racer. Scott mclendon is another one,That was actually a little faster than the Holroyd-one we had,but that was one of his early ones.. 7-8 years old probably..i'm sure Clarks lastest one's are as good as anyones!
bsa633 is offline   Reply With Quote
Old 04-12-2008, 05:10 PM   #5
BoydW
Cool Re: 780 Holley (LT1 carb) Setup for Super Stk
Wow, that's bizarre, what timing, you ask and you shall receive. I will give Frank a call. Thanks alot for all the info, I appreciate it. William
Old 04-16-2008, 07:49 PM   #6
cyclecyko
cyclecyko's Avatar
Dave Brazwell I may have misspelled the last name but he is the guy for holleys bar none
cyclecyko is offline   Reply With Quote
Old 04-16-2008, 08:00 PM   #7
crazyponcho
I have used Braswell carbs before and they are hands down the best you can get. I know he does carbs for prostock comp eliminator and nascar. go to braswell.com.
crazyponcho is offline   Reply With Quote
Old 04-17-2008, 01:41 AM   #8
SSDiv6
This is a SS/GT application, not Comp, Pro Mod or Pro Stock. Braswell specialty is Holley carburetors, highly modified for these classes; not for Stock or Super Stock.
One of the best for Super Stock class is Patrick at Pro Systems. He does SS/AH class Holley's and other Super Stock OEM applications.
http://www.prosystemsracing.com
