Old 07-04-2022, 07:15 AM   #1
Liked 10,720 Times in 2,232 Posts
Default Tire Pressure And Temperature Monitoring System
With 16 tires to check pressure on before we travel to and from the races, it was always time consuming and sometimes a little painful, old knees, to check. Now with the monitor I turn it on and in a few minutes every tire information is showing on the screen. What a time and tire saver. Alarm goes off on low or high pressure and high tire temperature.
This post may be in the incorrect section but I know everyone that races has to deal with this every trip.
Old 07-04-2022, 07:31 AM   #2
Keith 944
Keith 944's Avatar
Liked 1,877 Times in 577 Posts
Default Re: Tire Pressure And Temperature Monitoring System
Agree, I got one a couple years ago and am.very happy with the purchase.
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 07-04-2022, 07:31 AM   #3
4543
Liked 643 Times in 140 Posts
Larry,Which one did you install? Mike McMahan 2543 H/SA
4543 is offline   Reply With Quote
Old 07-04-2022, 08:10 AM   #4
EEZ RV Products with the pass through transmitters with a repeater on the trailer.
We were coming home from a race and got caught in slow traffic for a few miles. After a few stops in the stop and go traffic the trailer tires temp started to make the high temp alarm go off. We pull into a rest area to check and they are hot. The fix was realizing the trailer breaks were set to high and was doing most of the stoping. Lowering the controller a half a number and problem solved.
Old 07-04-2022, 10:12 AM   #5
4543
Thx. Mike
