Liked 18 Times in 8 Posts
Updated Parts List as of 9/30/2022:
2 - 4bbl Braswell Carbs with top, billet O-ring 4-hole sheer plates, linkage and hardware for SB2 HRE manifold: $1900 Meziere Big Block Chevy water pump black: $325 Star Vacuum pump and bracket: $400 - SOLD Dailey external oil pumps: - Single stage pump $400 - SOLD - Wet-Vac 3-stage pump with 2 vacuum ports: $700 - NEW 4-stage wet-vac pump with 3 vacuum ports: $1000 Rocker arm systems for SB2 heads: NEW - Jesel complete shaft rocker system for SB2 heads; aluminum solid body rockers 1.75 / 1.7 ratio, bars, stands, hardware. Complete kit: $1900 - T&D complete shaft rocker system for SB2 heads; steel lightweight rockers 1.75 / 1.7 ratio, bars, stands, hardware. Complete kit: $2400 427 LSX engine parts: - Coated pistons, pins, New stef aluminum oil pan and pick-up, beehive valve springs, retainers, keepers, rocker arms, pushrods, hyd. Roller lifters, camshaft: $1800 2 Complete Wedge Engines: - 2, record setting Short-Deck engines (316 CI and 321 CI) with the best of everything : $22000 / each - 316: Fresh, 0 runs - 321: 4 runs, all this year - SOLD - Call for more detailed information PISTONS/ RODS / PINS / RINGS: SB-2 / used perfect shape / 23 runs: CP Pistons 4.182 set of 8 / 1.430 c/h .020 x .020 x 3mm total seal ring set .927 x 2.250 x .240 wall titanium wrist pins MGP aluminum rods 5.202 OL x .927 pin with 1.777 bearings included: $1500 CP pistons for Splayed Valve head set of 8 / 4.157 bore x .866 pin diameter with total seal rings: $500 CP pistons for Wedge head 4.165 bore / 1.390 c/h x .927: $400 200 pushrods 3/8" 7.700 to 9.250 lengths: $50 set of 8 or $100 set of 16 Jesel .875 SB-2 tie bar roller lifters dyno time only. Perfect condition: $400 Driveshaft / Chrome moly 51" center to center / 1350 spicer u-joints / 39005-U yoke used one race: $300 5.83 Ford 9-1/2" Gleason Ring and Pinion polished and lightened used / perfect shape: $1300 6.00 Ford 9" ring and pinion US Gear rem finished, cryo'd, lightened / NEW: $800 6.33 Ford 9" Tom's differentials ring and pinion / NEW: $400 Please reach out to if you have any questions. Thank you, Cody Lane (206) 999-8369 cody.lane@hancockandlane.com Last edited by Cody Lane; 10-24-2022 at 11:53 PM. |
Liked 974 Times in 310 Posts
Which star vacuum pump and bracket to fit what engine?
