Old 09-29-2022, 07:00 PM   #1
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
Default M200 burnout procedure with auto 1-2?
Installing a new M200 that has Auto 1-2. Have always been told not to start burnout in low gear with 200’s. Last couple couple years I have been using 2nd only. So my question is what is procedure with these auto 1-2 units?
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
Old 09-29-2022, 07:20 PM   #2
J.R. Haddad
Liked 1,469 Times in 308 Posts
Default Re: M200 burnout procedure with auto 1-2?
High gear only burnout. It's easy on the trans. I understand it is what the 200 Guru's recommend, I know it is what Pro-Trans recommends.
J.R.
J.R. Haddad is offline   Reply With Quote
Old 09-29-2022, 08:33 PM   #3
jmantle
Liked 172 Times in 81 Posts
It's not the 1-2 shift that kills the sprag, it's the 2-1 downshift when the tires hook up, especially if you still have your foot in it. High gear only is what I recommend to my customers.
Jim Mantle U/V/SA 6632
jmantle is offline   Reply With Quote
Old 09-30-2022, 10:42 AM   #4
Andy Friar
Andy Friar's Avatar
Liked 226 Times in 76 Posts
Chipper, I know minimal about the M200's other than they are faster. How does the Auto 1-2 work? Tied into the ignition with a brain box to move the shifter? Suprised, without knowing mechanically/ electronically how it works, that Auto 1-2 shifts would be legal in stk. Very possible I am just misunderstanding the definition of auto 1-2. Thanks
Andy Friar
Andy Friar is offline   Reply With Quote
Old 09-30-2022, 03:50 PM   #5
James Perrone
Liked 1,829 Times in 427 Posts
Start burnout in second gear. 2-3
Like a power glide
Also if it a transmission with no cooling lines
Warm up trans consistently when racing
It helps repeatability
I’m have aMc Clay
james perrone 1290 STK
Old 09-30-2022, 03:52 PM   #6
JIM MARSHALL
Liked 337 Times in 46 Posts
Always do 3rd gear burnouts, the tire suppliers like it as well lol
Jim Marshall 1967 STK
JIM MARSHALL is online now   Reply With Quote
Old 10-01-2022, 02:49 AM   #7
john ancona
john ancona's Avatar
Liked 186 Times in 57 Posts
Auto 1-2 shifter in second burn out in low just to start go to third and stand on it ,like Jim say's the tire Guy's will love you ! Who's next how many LoL
John Ancona 717 STK / SS
john ancona is offline   Reply With Quote
Old 10-04-2022, 07:24 AM   #8
Chipper Chapman
The auto 1-2 feature runs off the governor and has an adjustable regulator of sorts regulating said governor pressure to make the shift point adjustable. There is also E-Shift valve bodies that uses a control box, supposed to only be used in EFI cars.
Thanks for the info guys, tried the high gear only, but at 3600 pounds with 4.33’s it didn’t like that, so I spent the weekend breaking them loose in low and immediately moving to high. 19 years of shifting on my own it’s a strange feeling, but it’s definitely a worthwhile upgrade!
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
