#32 | |
Liked 805 Times in 245 Posts
#33 |
Don't get me wrong here.
I'm always interested in discussions that pertain to 5/10th full tree, breakout, good RT required, S/SS racing. Also, Ken runs a tight ship. I assume he knows of 'Weedburner". A friend, wanted to use his signature to promote real estate sales to other racers.He was not a paid sponsor. ;-) He no longer posts here...
#34 | |
Liked 13 Times in 11 Posts
It wasn't my intention to get into clutches and "tamers"......I didn't even ask about clutches. My question was the consideration of the engines peak torque and power and how your launch RPM coincides with either. |
#35 |
To answer your question pretty basically, your best 60' will be at as high of RPM as your tires and valve springs will hold. I normally leave at 8400 but my best 60' was at 11,000, just can't cut a light at that RPM. Ever hear a Comp Elim car leave at anything below the max RPM can hold?
#36 | |
Liked 20 Times in 16 Posts
There is nothing proprietary about my original 'tamer. The first iteration was a simple hydraulic screen door closer that I bought at a hardware store and attached to the clutch pedal, also a simple sliding stop arrangement. No electronics. The version I make now is basically the same thing except with a much shorter cylinder. You can make your own for about $30 if you can fit the hardware store cylinder under your dash. If someone had come up with it 40 years ago, I doubt you guys would be using softlok style clutches today.
Grant website- http://ClutchTamer.com We make your non-adjustable clutch...ADJUSTABLE! Last edited by weedburner; 10-11-2022 at 04:04 PM. |
#37 |
Joe, I know you posted a generic question but it did Veer off from there. Just tell the people here what you do with your car and we'll probably have the answer. This is the stock super stock t e c h section
#38 |
Most threads on the 1st page with more views have been up for more than a month. This thread is only 5 days old.
Here's some pics of the original Hillbilly Clutch Slipper install using the hardware store VH440BL hydraulic screen door cylinder, everything was less than $20 at the time... ![]() ![]() ![]() Like I said, the current 'tamer functions pretty much the same except with a much shorter cylinder. Just a simple, repeatable way to control throw-out bearing position during launch.
Grant website- http://ClutchTamer.com We make your non-adjustable clutch...ADJUSTABLE! Last edited by weedburner; 10-11-2022 at 06:57 PM. |
#39 |
Which was why I asked in THIS section....
With the exception of a few reply's , there wasn't much "ON POINT" participation. Some times the "sensitivity" or "specificity" of these forums is ridiculous. I was expecting answers on point with the question only. I never asked about clutch management. "At the point of bogging , wheel standing or blowing the tires off how does your best "launch" RPM coincide with either peak torque or peak power? Probably a question better directed towards the "back halved" crowd with a 13/31-14/32 tire.... Opinions?" You can close it. Last edited by joespanova; 10-12-2022 at 10:34 AM. |
#40 |
May seem simplistic, by rather than worry about what the dyno sheet says, why not just try different launch RPMs, and see what goes the quickest? A dyno pull is quite different than how a car and engine work when going down the dragstrip, especially a stick car. On my low 10 second SB Ford, with a 4 speed and Soft Lok clutch, I find dropping the clutch at 6600 RPM, and shifting at 7000 produces the best 1/4 performance. Only real way to know is to experiment.
