#1 | |
Need to have sleeves made that slip on or wrap around with velcro fasteners, for where they cross. Still, it seems every time I stop, I've got to click the rear straps another notch.I think the longer they are , the more they stretch. Thinking about going back to chains in the rear.
#2 | |
Liked 225 Times in 136 Posts
I towed for years with straps crisscrossed an never had the wear problem.
Liked 133 Times in 76 Posts
Ever notice no one has a problem....until they do? I use 4 straps not crossed, all have safety style hooks fronts don't have ratchets only the back.
I have seen someone open the trailer door to find their car against one wall because 1 strap failed. OP is correct about the rough roads and the car bouncing. Slicks have a lot of give so for insurance I'll pump my tires up a little high before loading. If going any distance I'll stop and check my straps and tighten the ratchets. I used the D part of weld on D rings and welded them onto the car to tie down with. |
Liked 126 Times in 61 Posts
I cross the back straps and the fronts. I put the car in the trailer at running air pressure. I then add air to the slicks to a count of 15 to 20. The last thing is to snug the winch cable and I am done. Car has never moved. My typical tows are several hundred miles and my long ones are 1,000 to 1,500 miles.
Liked 52 Times in 22 Posts
If you tie your car down at the rear axle housing, try touching your shocks on the car after towing for an hour or so. The shocks are very hot. I don't know how this affects the life of the shocks or their function but I don't think it can be a good thing.
Years ago several of us stocker guys with open trailers left Bowling Green for Indy together. I couldn't believe how much the race cars were bouncing on the trailers. I often wondered why car trailers don't have shocks. |
Liked 105 Times in 26 Posts
On my Camaro I use “t” hooks that hook in the side of the subframe and in the rear I drilled a hole in the bottom of the frame rail and use a miniature “J” hook. I drilled the hole probably a foot from the rear valance.I can hook it while standing up and it doesn’t budge going down the road.
Liked 47 Times in 14 Posts
Have heard of door car using a chassis bladder under the front sub frame. after the car is fully strapped down then use place the bladder and pump it up to help keep it from bouncing in the front end I would think you have to be careful not to over load the bladder due to strap pressures could be hard on tie downs in trailer floor and frame of car.
Brett McFarland A/S |
Liked 84 Times in 42 Posts
This summer I left the track for home and 22 miles later I felt a bump from the rear when I stopped for a stop sign. A couple blocks more and another bump and stop. Decided to look into trailer and all 4 straps were broke. I know they were tight when I left the track. The front straps from the outside into the center of the front crossmember under the engine and the rear ones were one on each side from the axle straight back. The winches were both in front with no adjustment at the rear. I can’t figure out how all 4 could break but it happened.
I don’t have a solution but I bought very high quality straps to replace the destroyed ones. All the straps broke where strap is looped around her hook and sewed together. The sowing thread is what broke.
Bob Tilton 568 FS/H |
Liked 2,487 Times in 698 Posts
We have been building and selling trailers for 30 years or
more. I have seen a real quality difference between straps that are rated the same breaking weight. Some of the stuff at harbor Freight and the swap meets scare me. Be sure you D Rings are heavy enough and plated and welded to crossmembers securely. I have seen trailers that I would not trust my Grandkids bicycles on.
#10 | |
Liked 226 Times in 76 Posts
Andy Friar |
