Old 10-14-2022, 02:39 PM   #1
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Default Re: Towing question
I used a railroad tie piece of wood under my front crossmember. The turnbuckles hook into the frame and pulled down against the railroad tie. The frame will have 2 areas that the factory uses when transporting vehicles from the factory to the dealers. I haven't used any wood under the rear suspension as of yet. You can use chains with the turnbuckles if that helps. If you want pics send me your email. And yes it's a learning curve when you have to always travel the roads thru NYC.
Old 10-14-2022, 05:10 PM   #2
4543
Liked 647 Times in 140 Posts
I add air to all four tires, cross ratchet straps and tighten my shocks full tight. Also balance trailer tires. Big difference. Mike McMahan 2543 H/SA
4543 is offline   Reply With Quote
