Old 04-22-2008, 12:12 AM   #1
Mike Carr
Mike Carr's Avatar
Liked 83 Times in 37 Posts
Default Re: GT Class: Cold/Ram Air Hoods?
I believe Angelo's explanation is correct. Using the 90's Firebirds an an example, the FI LT-1's in SS/IA are allowed the ram-air. But, the same car with, say, a '69 350/295 motor in a SS/GT class would not be allowed to use the ram air hood, or the snorkles would have to be blocked.
Old 04-22-2008, 12:52 AM   #2
Stewart Way
Liked 70 Times in 22 Posts
Hope your wrong but who knows. As I read it in SS it states "Hood openings and/or hood scoops other than original equipment prohibited." Then for GT it states at the begining of the class "Requirements and specifications for GT class are the same as those for Super Stock classes - Section 10A - with the following exceptions." No exceptions listed for anything related to hood or scoops. I took that to mean if the body was originally equipped with a scoop it could be run in GT. As I said above, I had this confirmed by Jim Collins last year before I started in the car.
Won't really matter to me because I think the motor I will run was available with or without the shaker hood and the HP is the same.
Old 04-22-2008, 10:25 AM   #3
Lynn A McCarty
Lynn A McCarty's Avatar
Remember all the advantages of a GT car? This is one of the disadvantages.
We used to have one rating for Ram Air and a different rating for non ram air. It all of a sudden one day disappeared for SS. It is still there in Stock class.
My question are:
1.) What Super Stock rules eliminate the credit for non-ram air, but necessitate it for Stock class? Do they want the GT cars to pay the penalty for Ram Air even though they dont get it in most of the cars?
2.) If a GT car isnt allowed Ram Air, and the engine came with a Ram Air rating do we decrease 5HP?
3.) Many GM cars had "Fresh Air" which is plumed through the front, but not through the hood scoop, can we hook that up if the engine combo came with it?
4.) There seems to be a difference between an Open Hood and hooking up forced induction(by sealing up the RA hood with a functional air cleaner) . Cant seem to find a consistent answer, just like short decks or crank holes.
Lynn A McCarty 3470 SS
Lynn A McCarty is offline   Reply With Quote
