Old 10-20-2022, 07:54 PM   #1
a pontiac
Liked 36 Times in 11 Posts
Default Re: msd 8251
Had a miss, but only under load. Drive around pits no problem. Replaced everything we had with known good parts, except msd 7al box, tried good 6al and good coil cured miss. Msd repaired 7al box for less than $150. Of course, it is now the spare after buying a new box.
a pontiac is offline   Reply With Quote
Old 10-21-2022, 08:27 AM   #2
rick winchester
Liked 207 Times in 34 Posts
Installed new coil, cant really tell if it helped or not. Going to try another set of plugs because they look gas fowled before buying a new box. Maybe try to find someone who has a good spare to try. Thanks Rick
Rick Winchester Stk 3277
rick winchester is offline   Reply With Quote
Old 10-21-2022, 05:42 PM   #3
Monte Howard
Monte Howard's Avatar
Liked 71 Times in 23 Posts
2 things to check,
make sure there isn’t any rust on the pick up coil inside the distributor.
Make sure the wires that run from the MSD box to the distributor doesn’t run close to the coil.
Monte Howard 3209 STK, 3208 SS
Monte Howard is offline   Reply With Quote
Old 10-21-2022, 07:25 PM   #4
Willyracer
Willyracer's Avatar
Liked 57 Times in 24 Posts
Rick I have spare 7AL box and a digital7 box
Also have 2 different msd coils. If you want to try.
I was going to Edgewater on Sunday but you can have them
anytime to try.
David
Willyracer is offline   Reply With Quote
Old 10-24-2022, 09:33 AM   #5
rick winchester
Thanks for the offer, ordered a new one. If it does not help I will use it to upgrade the Camaro. Thanks again. Rick
