Old 11-02-2022, 07:34 PM   #1
MAURICE BLENDHEIM
Liked 285 Times in 87 Posts
Default Re: A Ladder Bar Hole Tuning/Adjustment
Craig… Do you have a Specific Problem you are trying to overcome? MB
MAURICE BLENDHEIM is offline   Reply With Quote
Old 11-02-2022, 08:50 PM   #2
CraigG
Liked 8 Times in 7 Posts
yes break loose on initial hit - recovers guessing 10 feet.
Want to understand relationship of bars to torque input.
Thanks, Craig
CraigG is offline   Reply With Quote
Old 11-02-2022, 09:20 PM   #3
MAURICE BLENDHEIM
What is your Baseline Setting? What Tires? What type of Car? Springs, Shocks ? There potentially could be other variables that are compounding your problem. MB
Old 11-03-2022, 08:07 AM   #4
Mike Pearson
Mike Pearson's Avatar
Liked 1,945 Times in 586 Posts
I race a ladder bar car. my car is set up with 2 degree down angle on the ladder bar with 2 degrees of down pinion angle. It will not work at all if the bars are past level or running up hill in the front. All measurements are taken in relation to the frame or rocker panel. if the car is set up correctly no preload is best. my car is 3140# and i have a 110 lb spring rate on the shocks. Typically the bolt holes are too coarse of an adjustment. I use ride height if i need to make any adjustments. Start with the shocks loose on the front and rear and the tighten as you test.
Mike Pearson 2485 SS
Old 11-04-2022, 09:06 AM   #5
SGSST109E
Liked 126 Times in 61 Posts
HAve you ever set your car up on scales? Do you have equal weight on the rear tires?
SGSST109E is offline   Reply With Quote
Old 11-04-2022, 05:12 PM   #6
Jeff Stout
Liked 706 Times in 283 Posts
I think knowing height of front holes in relationship to rear end brackets holes would need to be first. Then plotting out if the bar is going down, straight or uphill.
Old 11-07-2022, 10:09 PM   #7
CraigG
Hey thanks guys I really appreciate all your good input.
I think the next step is to follow through with many suggestions and is to be able to individually scale all four wheels, invest in a good pair of double adjustable rear shocks and look at springs and height adjustments – of course getting a good video to review and share.
Any other ideas are also greatly appreciated.
Thanks, Craig
