Old 11-04-2022, 12:05 PM   #1
B Parker
Liked 2,343 Times in 465 Posts
Default Re: Billet cams and lifter supply
If I could have liked this post 100 times I would have.
Bubski Grow a pair and use your real name.
Frank I'm sure we must have met threw the years but do you even have a Stocker?
Paul you and Charlie are trying to get a motor built. What are you going to use for lifters? Or are you going to put a small cam with not a lot of valve spring pressure.
There are others on here with a solution to go backwards for the older cars. Some of you don't race Stock and probably never will. Others race in classes that they don't have anyone that competes in their class and won't see a heads up race all year. I'd call that bracket racing and you don't need to worry how fast your car goes. I like the part of competing against other cars that run the same class as I do. And I don't want to have to bring a knife to a gun fight because a part is no longer available.
James so you have an experiment going on. I hope they work all season.
But if not let us know how big of a hole in the oil pan they put and what it will cost to fix.
I don't need any lifters at this point. But with everything we are allowed to do right now. And with half the cars in Stock using roller lifters already. You think letting all Stockers use them is going to make us closer to Super Stock. Really!!
That horse left the barn years ago too.
Bubski pay attention to this. I USE MY REAL NAME again if your going post on here why don't you first grow a SET !! Until then I look at your post's as a no name CLOWN. Barry Parker
Old 11-04-2022, 12:21 PM   #2
Nmbr1GMfan
I have a cast cam, removed the billet core so we could try a different grind, everything looks good but I'm sure it's all on borrowed time. I would like to get a billet copy of our current can but that is obviously an issue. Here was my fix...I ordered a roller cam, aluminum heads and manifold, plus a 4150 carb and a nitrous kit. I'll mothball the stocker stuff and maybe someday when lifters aren't $2k we'll return...maybe not.
Todd Greene
