Old 11-19-2022, 04:35 PM   #1
treetrimmer
Liked 2 Times in 1 Post
Default 1985 Camaro G/H/I Stick
85 Camaro G,H,I Stick
305 (C.P.,Scat,Shubeck,CompCams)
Jerico DR4 trans
Long shifter
QuickTime bellhousing
Youngblood clutch
Dean Oliver quadrajet
Aeromotive fuel pump and regulator
MSD 6 digital ignition and distributor
Complete Strange 12 bolt rear 5.13 gear
Strange aluminum rear shocks
Koni font struts
Aerospace front discs drum rear
Pete Z traction bars
Stahl jet hot coated headers
Tig welded cage
Optima battery
M/T tires
Aluminum fuel cell
Have title for car
Spares and Extra
Block,4 heads, 2 intakes,Oliver carb,carb tuning parts,clutch and pressure plate,spare first gear and jerico parts,complete set of new gauges, C12 fuel
Complete turnkey stock setup with all spares!
$18,500
Call Shawn 610-287-4856 ( this is a landline no text leave message and I will return calls after work) Thanks!
Last edited by treetrimmer; 12-04-2022 at 04:06 PM. Reason: Sold thanks classracer!
treetrimmer is offline   Reply With Quote
Old 11-20-2022, 08:16 PM   #2
bts922
Default Re: 1985 Camaro G/H/I Stick
Can you send me pictures of the car and how many runs on the current setup
bts922 is offline   Reply With Quote
Old 12-04-2022, 04:09 PM   #3
treetrimmer
[QUOTE=treetrimmer;671152]85 Camaro G,H,I Stick
Jerico DR4 trans
Long shifter
Youngblood clutch
Koni font struts
Tig welded cage
Optima battery
M/T tires
Aluminum fuel cell
Have title for car
Spares and Extra
$18,500
Call Shawn 610-287-4856 ( this is a landline no text leave message and I will return calls after work) Thanks![/QUOTE
SOLD! Thanks Classracer
Search this Thread:
Advanced Search
