Hello, Which agm 16 volt battery do you prefer?
XS power batteries or TurboStart, or something else? Thank`s Torbjorn Laas Sweden |
Liked 456 Times in 148 Posts
XS battery's. But what ever AGM 16 V you buy MAKESURE its packaged correctly so it will arrive with no damage. I have had several damaged in shipping especially the 76 lb group 27 ones. They are heavy!
Good luck, Steve Teeter Stk/SS 620 |
Liked 805 Times in 245 Posts
I have an old pair of 16V Turbo starts that are at least 10 years old and work perfectly. In my other car, I have a pair of Turbo starts that both died in about one year. Based on that, I am thinking that something has gone wrong with Turbo Start's manufacturing process. I have switched over to XS, no problems so far.
Liked 1,868 Times in 422 Posts
I've got one of the 16 volt chargers that went down, and no one can work on the expensive boat anchor, you can't buy parts for it, either.
I'd rather have a good 12 volt AGM or lithium battery.
Alan Roehrich 212A G/S |
Liked 133 Times in 76 Posts
Asisde from spinning the starter faster what is the reasoning/purpose for using a 16v on a car with minimal electrical useage? Is it for powering the ignition when not charging with an alternator?
Liked 129 Times in 53 Posts
For a Stocker with working alternator (as per the rules
![]() I found that lithium 12V battery's spin engines pretty good ![]()
Stop global whining |
#8 | |
Liked 348 Times in 152 Posts
Phil Molski PMR Performance S/C 1623 |
Liked 288 Times in 109 Posts
I now have several years of experience with 16-volt systems. I do not see any advantage to the 16-volt battery, and I have returned to a 12 volt with alternator. I now think that overall, the 12 volt has the most advantages.
Liked 172 Times in 53 Posts
I put one in my stocker last year. Fuel pump works better, with the fan and water pump running I can cool my car in about half the time that I used to, maybe less than that.
