Old 01-20-2023, 07:05 PM   #1
Jim Hanig
Liked 99 Times in 49 Posts
Question Re: No Blinders
Hey Billy, Here’s a good place to start….remove the 327 intake manifolds from the 283’s ……..
And 55 mm cams 250 lb valve springs rocker arms on and on and worried about blnders
Old 01-20-2023, 08:35 PM   #2
bubski
Liked 165 Times in 60 Posts
Default Re: No Blinders
Bubski is like WTF !! This Crazy Train has gone off the rails again !! 459 intakes and big journal cams n other enhancements and begging for HP reductions have nothing to do with this nonsensical thread !! What ever happened to PERFORMANCE based classes ?? Now we need blinders , as many calipers as you could possibly mount on the rear brakes of your "STOCKER" more stopping power than a dump truck , Super Mega 1000000 n the like adjustable trans brake buttons on your SS car , Coors light 30 pack blinders on your windshield and helmet !! multiple step rpm limits and on track data acquisition !! to name a few !! Remember this is PERFORMANCED based not Bracket 1 based !! Bubski believes all this nonsense can be put away for good by only allowing Hi side rev limiters , no more trans brakes , no more blinders ,no more 4 caliper rear brakes , no more data acquisition , no more fancy digital ignition systems !! Just what it takes to make the car run !! REMEMBER as you talk down to the bracket guy that STOCK, SUPERSTOCK is more than a bracket race !! And your begging for all the bracket racing luxuries !! Back to the 85b !! CBN fitted now !! CHEERS !!
bubski is offline   Reply With Quote
Old 01-20-2023, 08:45 PM   #3
Bob Gullett
Bob Gullett's Avatar
Liked 510 Times in 117 Posts
https://www.nhraracer.com/content/ge...715&zoneid=132
Are you kidding me? This is the reason for banning blinders? And hood scoop cars that drive around haven’t just about ran over or crashed into a few things because they can’t see a thing? Wow.
68 Chevy11 327 F/S
Bob Gullett is offline   Reply With Quote
Old 01-20-2023, 08:50 PM   #4
Keith 944
Keith 944's Avatar
Liked 1,887 Times in 579 Posts
so thats the real reason, maybe they should be more concerned about all the kids driving carts, scooters and bikes around, then take something away from the racers....
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 01-21-2023, 04:58 PM   #5
doglover44
doglover44's Avatar
Liked 499 Times in 236 Posts
What pit accident or accidents were so bad that blinders are now not allowed ?
Jake Biermann
Old 01-22-2023, 12:14 PM   #6
james schaechter
Liked 1,448 Times in 303 Posts
I will say, I could care less if other racers lose their blinders. I have thought about it but I just didn’t want it be enough to commit. I also don’t mind racing against racers that use blinders. It doesn’t affect me.
That being said, it sounds more like an on track agenda rather than the data leading NHRA to this change.
If NHRA had a concern in the pits, but not on the track, why not just say to remove any blockage post run after the racer had safely left the racing surface? I know of 2 pretty bad crashes in the pits due to drivers reading their time slips instead of watching where they were going. Do we not allow timeslips in the race car now then?
If an OEM sun visor is ok, why not allow blinders that attach to a roll cage and can be flipped up out of the way easily? At least some sort of reasonable guidance would seem to be in order. As long as it doesn’t end up like the total hose job collector tethers were. Remember the (accepted ) models that were way overpriced?
I will say over the years I have seen some really bad attempts at blinders. I saw racers that looked like they had a card board box taped to their helmet or a windshield taped up in an extreme way.
I am more concerned with the guys that have their belts super loose and are looking behind them most of the way down the track.
On the other hand, if NHRA is taking the position that the blinders are an unfair driver aid, then why not just say so?
If they are going there, why not take away the brake pressure switches?
Like I said, I don’t use a blinder, and I don’t mind racing drivers with blinders, but it sure seems like NHRA is afraid to say why they really changed the rule.
James Schaechter 3163 STK
Old 01-22-2023, 12:17 PM   #7
FLEMING
Liked 56 Times in 26 Posts
People will just go back to using there hand like back in the day.. Bertozzi and herrington did this as well as many others.. The cream will always rise to the top..
FLEMING is offline   Reply With Quote
Old 01-20-2023, 08:54 PM   #8
MR DERBY CITY
Liked 8,260 Times in 1,543 Posts
What a FRICKEN crock of chitt …...Who in their right mind would keep their blinder pulled down while driving through the pits…
Old 01-20-2023, 10:39 PM   #9
Stan Hawes
Liked 87 Times in 17 Posts
Is a stock sunviser considered a blinder ?
Stan Hawes
Stan Hawes is offline   Reply With Quote
Old 01-21-2023, 12:11 AM   #10
mitch kight
Liked 50 Times in 15 Posts
Two-steps are next!
mitch kight is offline   Reply With Quote
