Old 01-24-2023, 03:03 PM   #1
Rob Petrie E395
Liked 216 Times in 77 Posts
Default Re: No Blinders
Use an iridium or tinted shield. Put tape on the inside and it can’t be seen. Flip the shield up as soon as the car leaves so you can see normally going down the track. If you have trouble holding your head still. Wear a neck collar and tilt and hold your head against the neck collar to steady your head. They won’t check helmets. They don’t check half the stuff they should. If you ever want to see my helmet just ask. I don’t do this. But I know guys that do. That’s how I know how it’s done.
