Old 03-01-2023, 11:58 AM   #9
dartman
dartman's Avatar
Liked 68 Times in 41 Posts
Default Re: 2023 AHFS system "cliff note version"
Originally Posted by Mike Gray View Post
Not that I disagree with you but when do they run fast? Why have a fast car and never run it to its potential? Is it just the hopes of going to a National Open or an Allstar race with no AHFS to go fast. I would be skeptical of record runs at those races. Do they tear down at those events?
Maybe a way to speed up the AHFS is to eliminate dial under ( It’s not bracket racing) run off the index which will be like heads up and cause the AHFS to adjust the combo’s much quicker. If the thought is only the big money fast cars will win it should only be short lived as the hp adjustments should bring them back to the field.
They do tear downs at D1 opens every time a record is set in Canada.Seen it done many times.
1231 FS/D Drag Pak
1231 E/SA 71 Demon
Kelly MacKay
dartman is offline   Reply With Quote
