Liked 115 Times in 35 Posts
Which port should go to the front brakes on the mopar/chrysler aluminum master cylinder?
I have seen this master on many cars and plumbed both ways. Mine is front port to front brakes. Correct? |
Liked 91 Times in 51 Posts
That is how mine is plumbed.
Liked 346 Times in 126 Posts
do you use the one with the largest brake fluid capacity?
Liked 1,877 Times in 577 Posts
The larger Reservoir goes to the brakes that hold the most amount of fluid
Liked 882 Times in 236 Posts
Per the instructions for a Strange Mopar style master cylinder. The reservoirs are the same size front and rear, however the piston volume is larger on from the port closest to the pushrod.
■ The outlet port nearest the pushrod supplies the most fluid volume and should be plumbed to the calipers requiring the most volume. Typically a drag race only car will have the largest calipers on the rear, while a street driven car will have the largest calipers on the front. Attach lines accordingly Since most S/SS cars have the same calipers front and rear it really does not matter although I always plumb the larger section[ closer to the pushrod] to the rear brakes.
#6 | |
Liked 805 Times in 245 Posts
Jim, mine is front brakes, front port.
Joe Martens AA/Stock 3969 |
Liked 133 Times in 76 Posts
It's a straight bore MC so pressure has to be the same at both ports. The rear piston will move slightly quicker than the front one as they are tied together with a spring. The rear port will provide a little more volume so if you have front disc and rear drum plumb the rear to the front disc. On many MC's the one section will have a larger reservoir as that was the end that was plumbed to the front dis brakes as disc brakes are self adjusting by using fluid to fill behind the piston as the pads wear.
#9 | |
Liked 920 Times in 259 Posts
And make sure there some sort of retainer, besides the rubber ring, to positively keep the pushrod in the MC. |
