Old 03-23-2023, 08:55 AM   #1
Tim Barrett
Liked 472 Times in 72 Posts
Default I need to apologize!!
I thought I knew the 2023 AHFS rules that are in effect for 2023 Stock, Super Stock season. I thought that any fast runs could be,,FIXED,,through the season by runs .650 to .850 under. I was TOTALLY wrong and at the Divisional at No Problem Dragway in February in the final for G/SA class I went
1.127 under for the win.
In the new AHFS rule #7 states,, if the engine combination reviewed is deemed to be over the .850 max,,then the fasted run under through out the year will be used to calculate how much horsepower increase will be made,,even though we had minimal 0-20 oil,iced intake and chilled the engine.
There is NO correcting our fasted run.
I apologize for not reading the rules correctly,but now after the damage has been done,,there's no correcting.
Our combination is the 69 Camaro 350 255 280hp. We've had our butts kicked so many times over the past many years and now we finally worked on our combo,spent lots of money only to maybe screw up our combination. This used to be fun.
I can except any comments.
Tim Barrett is offline   Reply With Quote
Old 03-23-2023, 09:08 AM   #2
GUMP
Default Re: I need to apologize!!
You have time to lower the average.
Daren Poole-Adams
NHRA Stock/SS 2007
Old 03-23-2023, 09:41 AM   #3
Liked 11,012 Times in 2,263 Posts
It’s now a math problem. How many runs at .650 to .680 under will it take to lower the engine average less than .850 under? The only place safe will be the All Star race and the Sports Nationals. You may bring your average down in your class, but if someone with the same combo in a different class averages .850 everyone will get hit. The best hope is if the trigger has only been pulled once!
Good luck in walking the tightrope.
Old 03-23-2023, 10:10 AM   #4
devo340
devo340's Avatar
Liked 168 Times in 30 Posts
On a bye run, if you only make a cruise run (20 second pass), does it get averaged in?
What if you only break the beam & back out?
devo340 is offline   Reply With Quote
Old 03-23-2023, 10:27 AM   #5
MR DERBY CITY
Liked 8,225 Times in 1,538 Posts
Tim, you are fine. It’s still early in the season. In the Sorensen Brothers we Trust. They will get it all ironed out , they always do…..
Old 03-23-2023, 10:28 AM   #6
Doug Hoven
Liked 869 Times in 165 Posts
It doesn't count. The rule was changed so that you have to go .65 under for the run to count towards the average. It seems that I am part of the small minority that actually thinks the new AHFS rules will sort out some combos in a hurry. That being said, I might have a different opinion if I had just spend $20k+ on a new engine, just to have to add weight by next year. What I would like to see, but will most likely never happen, is if someone goes wickedly fast, for NHRA to make an effort to make sure their stuff is legal before the entire combo suffers.
1189 F/SA
Defunzalo Racing Enterprises
Old 03-23-2023, 10:31 AM   #7
MJ I don’t think the 350 Chevy holds that much water.
Old 03-23-2023, 12:05 PM   #8
1347
1347's Avatar
Liked 1,032 Times in 283 Posts
No, runs under .65 won't count.
Duane Hoven
1342 SS/GT
1347 is offline   Reply With Quote
Old 03-23-2023, 01:09 PM   #9
Dirk Olson
Liked 172 Times in 46 Posts
I know that this will not sit well with a lot of you. I rarely post but I feel that I need to a least vent on this.
All the money that we spend to make our cars faster and more competitive only to be hand tied to go too fast and hurt our or our combo. To some it's all about the win to some it's all about how the car performs. In the end the blend of both is desirable. The current policy in place to me is confusing at best. and now we have good people with fast cars making decision based on index rather than making the car fast and consistent. Not sure this right and in the good spirt of class racing good for the sport. I know that there will be poo poo,rs so I guess let the dart throwers have at it.
Dirk Olson
A/S 5036
Dirk Olson 5036 STK
Dirk Olson is offline   Reply With Quote
Old 03-23-2023, 02:51 PM   #10
Tim, Not sure what you're apologizing for .
For winning class?
For hitting the trigger twice?
For taking too much win light in the class final and putting your combo in the second tier for HP?
Be that as it may, the year end average for your combo has to be under -.85 .
If it's above that, what ET was used in the past to determine the HP hit? What's new then?
You can still lower the average by running.65 to .849 under as has been done every other year with this popular combo.
Am I missing something else new that pertains to Tim?
Anybody?
