Old 03-28-2023, 08:07 PM   #1
Dave Turner
Dave Turner's Avatar
Liked 364 Times in 138 Posts
Default Re: Wheel issue
Drum brakes Jon?
Dave Turner
SS/GT #1153
Old 03-28-2023, 09:35 PM   #2
Rose Racing
Rose Racing's Avatar
Liked 226 Times in 74 Posts
Originally Posted by Dave Turner View Post
Drum brakes Jon?
Jegs disc brakes
Rose Racing is offline   Reply With Quote
Old 03-28-2023, 10:37 PM   #3
Dave Turner
Originally Posted by Rose Racing View Post
Jegs disc brakes
3” studs (1/2” should be fine) and open end acorn nuts are the ticket.
Dave Turner
SS/GT #1153
Old 03-29-2023, 11:14 PM   #4
Rose Racing
Okay thank you Dave
Old 03-30-2023, 12:28 AM   #5
FED 387
Liked 333 Times in 180 Posts
save your time chasing unknown wheel vibration gremlins and buy a set of hub centric rings they come in many sizes and are made of aluminum OR plastic---about $8-14 a set of 4 (you only need 2) one for each wheel depending on the size and the supplier --Amazon has them $14 or so ---- you are gonna end up buying them eventually ---just for the record the hub supports the weight of the car the wheel studs are designed to clamp the wheel to the axle NOT support the weight of the car---over time the studs may bend or break because of the load put on them---its your choice do what you want but do a little research and read up on this----Good luck FED 387
Old 03-30-2023, 12:31 AM   #6
JGrossijr
JGrossijr's Avatar
Liked 460 Times in 59 Posts
Search "Hub Centric Ring Adapter Set"
Lots of options
JGrossijr is offline   Reply With Quote
