Old 07-16-2023, 03:06 PM   #1
littlemanjoe
Liked 75 Times in 28 Posts
Default 2 step & pressure switch
Has anyone ever had an issue with your 2 step not turning off clean during the launch?
I have developed a studder during the launch.
It shows the O2's going rich almost like it's a ignition thing.
littlemanjoe is offline   Reply With Quote
Old 07-16-2023, 06:29 PM   #2
Willyracer
Willyracer's Avatar
Liked 57 Times in 24 Posts
Default Re: 2 step & pressure switch
I assume you have a data recorder in the car. We bring the
12v signal from the pressure switch / 2 step into a digital input
Then you can see the 12 v drop and rpm increase. Our O2 sensor goes
rich on the hit also.I assumed it has to do with the vacuum secondary
in the carb
David
Willyracer is offline   Reply With Quote
Old 07-17-2023, 10:46 AM   #3
SDT1DYI
Liked 453 Times in 146 Posts
Yes, a bad Pressure switch can cause this. I would change it out .
Steve Teeter. Stk/SS 620
SDT1DYI is online now   Reply With Quote
Old 07-17-2023, 11:21 AM   #4
littlemanjoe
David, I do have a Racepak. I will order the 12 volt event sensor.
Steve, good point. I will change it out while I'm at it.
Thanks,
Mike
Old 07-17-2023, 03:42 PM   #5
Plyguy63
Liked 7 Times in 5 Posts
Thanks,
Mike
Some pressure switches have buna type o-rings or wetted parts. Buna rubber is not compatible with brake fluid. EPDM rubber is compatible with brake fluid. Virtually all brake o-rings, seals, etc are edpm rubber. Not sure as to what extent that has with the switch, but I know one person who had a switch go bad and his had buna rubber parts.
Plyguy63 is offline   Reply With Quote
Old 07-19-2023, 06:29 PM   #6
B Parker
Liked 2,336 Times in 464 Posts
I get your using brake pressure switch but are you using one in conjunction with a button on the brake pedal. If you are that's the first thing I would get rid of.
Old 07-24-2023, 10:04 AM   #7
Coleydog
Liked 53 Times in 38 Posts
What is the switch to buy?
Old 07-24-2023, 03:28 PM   #8
Plyguy63
I was doing research on switches and most have buna rubber. I think there is a place on the east coast that has epdm rubber pressure switches. I think that it is saved on my work computer. I will check and see.
Old 07-24-2023, 11:22 PM   #9
littlemanjoe
If someone could share what brand pressure switch they have had good results with it would be greatly appreciated!
Thanks,
Mike
Old 07-25-2023, 11:16 AM   #10
weedburner
Liked 20 Times in 16 Posts
I use a Harley brake lite switch, no problem in the 5 years it's been in place.
I've also used Napa SL147 and SL143, both VW brake lite switches.
Grant
Grant
website- http://ClutchTamer.com
We make your non-adjustable clutch...ADJUSTABLE!
weedburner is offline   Reply With Quote
